Question about Karcher 1750 psi Electric Pressure Washer
Karacher k2.180 wont start
Switch
Owners manual Karacher 395
Download from Karcher website free
Sep 27, 2016 | Karcher Garden
My 2004 freestar wont start battery good it used to start if i shifted it into neutral but now wont start in any gear
It should start in park and neutral .Their are safety switches to provident it from starting in gear. Like a clutch switch on a standard so you don't drive through your garage door .
The part is called an interlock switch typically mounted on the drivers side of the transmission.Also depending on if it is cable or electronic operated .Also could be the switch in the muilty function switches that control the shifting at the steering column
Sep 11, 2016 | 2004 Ford Freestar
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
https://www.youtube.com/watch?v=2WF71WdGn_g
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
My car wont start sometimes i can push start it but it wont jump start is that clutch pedal lock switch?
sounds like clutch switch, Check under dash follow clutch pedal up and see if there is a switch under dash, should be Purple wires going to it Heavy gauge wires, need to unplug it and put a jumper in from one side to other and cover with tape so it doesen't touch and ground out and blow a fuse, then see if it will start and if it took care of your problem, if so replace switch
Jan 05, 2012 | 1999 Saturn SL
Have a Karacher k-3.86 ELECTRIC pressure washer
Check the reset button on the GFCI plug to be sure it's in. Once you pull the trigger keep holding it for at least 10 seconds to let the water push the air out and then it should start running.
Apr 16, 2010 | Karcher K 2.25 R Electric Pressure Washer
A 1997 FORD TAURUS WONT START IVE REPLACED KEY SWITCH AND IGNITION SWITCH AND KEY HAS PLAY ACCESSORIES WONT WORK AND CAR WONT START
There is a plastic piece that goes between key switch and ignition switch that might be broke have the same issue and trying to find out how to replace this piece.
Mar 15, 2010 | 2004 Ford Taurus
ROPER RED4340SQ1 WONT START THERMAL SWITCH GOOD, START SWITCH GOO
Check for 220 volts at the terminal block. Check the door switch for continuity. Check for burned/broken wires.
Jan 03, 2010 | Whirlpool Dryers
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Karcher 1750 psi Electric Pressure Washer Logo
23 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
