Question about HP OfficeJet 6110 All-In-One InkJet Printer
New cartridge fails to connect
I just changed my hp 56 inkjet print cartridge which I have done many times before. It fails to connect, red lamp goes on, says waiting for cartridge to go readjust (all in Swedish) but also that something is (the line?) is occupied. Now there is an alarmin cracking sound and I fear the start of a smell.
I put the empty cartridge back into the machine and all the above occurs.
No fun at all!
Gunnel Andre
gunnel.andre@telia.com
It sounds like the print cartridge is bad. Pull it out and look at the electrical contacts. If there are scratches going from one across to the other or ink on the contacts, you could be shorting out the cartridge. Is this a refilled cartridge? If so, all bets are off. Throw it away and buy an HP original print cartridge. Also, look at the contact points inside the printer carriage where you install the print cartridge. If you see ink across the contacts, take a cotton swab with a very little bit of water (not dripping) and wipe the contacts. If you see the dimples collapsed, you have a problem. This is extremely rare however, but can happen if something is jammed into the carriage.
Put your old one back in and see if the printer responds. This is an easy check to see if it is the printer or the print cartridge.
Posted on May 29, 2009
I refilled my #56 and bought a new cartridge for the #57 and it says color cartridge 57 failed but if i remove the #56 it kinda works but doesnt print everything and takes forever to print.
i think your colour cartridge is chocked up .clean it ,pour the head of the colour catridge in hot water then clean it from tissue and enjoy ur printing.
Jan 14, 2011 | HP PhotoSmart 7760 InkJet Printer
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1315 Printer
57 No. cartridge is defective. Through it in a dustbin and purchase a new one
Sep 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
528 people viewed this question
Seeker5211
Seeker5211
