Question about Samsung Computers & Internet
Not starting up
There is sound in bottom of laptop
    Champion:
  • 232 Answers
Could you describe the sound it is making? Even better yet, if you could shoot a small video click and attach it to this tread that would be great.
Posted on Jan 09, 2014
I can;t get any sound on my laptop
Update or uninstall then reinstall a new sound driver to your laptop.
Sep 28, 2014 | Toshiba Satellite Computers & Internet
Tip
Fix OVERHEATING Notebook
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Turn off mute
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
also right click on the speaker icon in the bottom toolbar (bottom of screen) you will have an array of options select either playback or recording devices then communications make sure the mute all sounds does not have a tick in the box.
Nov 26, 2013 | MSI Computers & Internet
Sound is not coming from my laptop
Hello. Do you have other sound/ sound effects coming from your laptop when you are doing other things? I ask this to find out if master volume is turned up or not. There are two ways to check your volume settings. One is to move your mouse to the bottom of the screen and click on the icon of a speaker. This will be on the right bottom. If it is there DOUBLE CLICK on it to bring it up. just click and drag on the slider to increase the Master Volume. If the icon is not there then click on START and click on CONTROL PANEL. In there will be Sound or Audio choices depending on which version of windows you have. Click on Speakers, Click on Properties, Click on Levels and Increase your Audio.
Hope this helps...
Nov 04, 2012 | Acer Aspire 5920-6727 Notebook
How can i check my micro phone is working properly or not?
Click Start/Control Panel and look for Sound or Audio. Look inside it to see if Microphone is check as an Recording Device. If not the other party will never hear you. You can also get to Audio Sound by clicking the megaphone that is located at the bottom right near the time.
Depending on your operating system you can click Start/Program/Accessories/Entertainment/Sound Recorder you can test your microphone by using the sound recorder.
Apr 23, 2012 | Dell Inspiron 15 Laptop
I have sound but none when logging on to windows
1. check the sound mixer or the sound device to see if you have "play sound upon windows start up" checked.
Windows 7:
go to control panel > then select "Hardware and sound' then next select "change system sound" check box towards the bottom of this screen.
Aug 02, 2011 | Dell Inspiron 6000 Notebook
Hi my laptop is fujitsu A series AH530... The sound is very low..how can I increase the sound volume.?
you can increase the sound by going to start, settings control panel, sounds and audio devices and change the sound volume there.. Or double click the speaker near your clock in the bottom right hand side of your screen
Apr 07, 2011 | Fujitsu Siemens AMILO D-7830 Notebook
There is no sound and volume on my laptop.
if you have the sound driver for your laptop, try to reinstall it.
Also, check if you have the volume controller icon appearing in the system tray (desktop-bottom right) and check if the sound and speaker control are not in mute.
Feb 05, 2009 | HP Compaq Presario 700, 700A, 700AP,...
ASPIRE ACER 9410Z...sound wont work
Maybe it's something to do with the drivers. You can try and perform a reinstall by going to start ---- programs --- acer recovery manager ----- click restore at the bottom and reinstall teh drivers from there.
Apr 30, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
