Question about Kyocera Mita Office Equipment & Supplies
My copier does not fix copies and lamp is not coming on
  • peter kraft Dec 27, 2013
    Hi George Mukoshi, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What model do you have, is there an error code?
  • George Mukoshi
    George Mukoshi Dec 30, 2013
    My kyocera copier is KM4050 >It doesnot show any error but once you print ,the writings don't stick on the paper and the lamp of the fixing unit doesn't come on.
  • 46 Answers
Hi George, that is weird because the machine should error out a c60xx. If the fuser unit is cold without error code i'd go for a bad board.
In case the fuser is hot, you should check the pressure roller/springs.
I hope this helps
peter
Posted on Dec 30, 2013
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
Black copies
If it's copying all black then here's a test. Lift the lid and look at the glass plate where you would normally place your original, when you push the start button does the lamp under the glass illuminate? if not then we've found the problem, the lamp or it's driver is faulty and it will require a technician to fix it.
Dec 17, 2009 | Canon PC-940 Black and White Copier
Copy lamp Does not come on
Do you get a error code? I would say if the lamp is not turning ON it needs to be replaced or the thermal fuse is blown. Ceck for inpedence acrossed the two
Jul 02, 2009 | Sharp AR-5320 Black and White Copier
Copies coming out almost blacked out
Hello sir; Try to make a copy with cover open, then you can see the lamp is on or not, if not then check the thermos fuse at the ned of exposure lamp or exposure lamp, otherwise you ha go to check the drum blade isn't under good condition if everythingare good final you have to replace developer.
May 29, 2009 | Toshiba e-Studio 350 Copier
Machine over heated now the copies are black
Do the copies come out totally black or just dark???? Does the copiers scanning lamp turn "ON" when you go to make a copy? If you smell something burning, you may have paper wrapped around the upper fixing roller...
Apr 28, 2009 | Sharp AL 800 Copier
Copier produces no image
if you are getting blank pages from you machine then the scan lamp is blown or something else is cause but if you lift the lid and hit start and dont see the lamp come on then the lamp is the issue
Feb 02, 2009 | Canon PC-420 Copier
All the copies are coming out solid black
Dear sir ; Check the exposure lamp or thermo fuse for exposure lamp. Stii have problem ? let me know.
Jan 14, 2009 | Copystar Royal - COPIER STAND Copier
Kyocera copy machine prints all black pages??????? How to fix???
This is a common problem normally caused by the failure below-
The lamp that normally illuminates the original has probably failed.
The machine is producing what we call a 'sky copy' if done on a working machine.
The cover is left open and no original is placed on the table, causing little or no reflection back to the drum or sensors.
Leave the cover open, run a copy to see if there is any light coming from the scanner.
If not, you need the lamp replaced.
Jun 30, 2008 | Canon NP 6050 Copier
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
