Question about HP LaserJet 3055 All-In-One Printer
How to reset internal memory of hp laserjet 3055
    Problem Solver:
  • 33 Answers
Perform the following to clear the fax memory:
Press the menu/enter button on the control panel.
Press the > button once to select Fax functions , and then press menu/enter .
Press < or > to select Clear saved faxes , and then press menu/enter .
Press menu/enter to confirm deletion.
Posted on Dec 27, 2013
4 Suggested Answers
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
xptareq2000
  • 1447 Answers
SOURCE: HOW TO CLEAR PAPER JAM HP LASERJET 3055?
please you see your copier paper feed sensor is open or delivery sensor is open or broken
Posted on Jun 28, 2009
  • 102 Answers
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Hp laserjet 3055 scaner error3
Reason:
CCD unable to detect the home.
Solution:
# Clean CCD unit(internal mirrors & lamp reflector). # clean flat bed glass. Fix back & chk. If not resolved chk CCD ribbon cable, # replace CCD unit..
CCD unit:
Oct 18, 2013 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
Hi I am getting an error message 232 on my HP Laserjet 3055 - it says on the screen that it is low on memory but I can't find where to reset the memory if this is the problem. Thank you
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
As far as I know, there is no option to turn this Fax Caching option off.
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055. All of a sudden it stopped working. after powering up, it does "nothing" HP appears in the menu window, but that's it. none of the keys works, no way to even test it. All cables are...
Perform a cold reset
  1. Turn the printer on.
  2. Watch the control panel.
  3. When the memory starts counting, press and hold the green c00007906.gif (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
  4. Release the c00007906.gif (Select) button.
  5. The control panel will display SELECT LANGUAGE .
  6. Press c00235041.gif (Down Arrow) button until control panel displays COLD RESET .
  7. Press c00007906.gif (Select). The printer will perform a cold reset and then continue its power-on sequence.
Dec 14, 2009 | HP LaserJet 3055 All-In-One Printer
Memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
Nov 12, 2008 | HP LaserJet 3055 All-In-One Printer
How to reset an HP LaserJet 3055
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
Jun 19, 2008 | HP LaserJet 3055 All-In-One Printer
HP3055
Hi Have you tried to do a factory reset on it, incase anything is stuck in the onboard memory, you could also check the memory settings in the printer management menu.
Feb 19, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
181 people viewed this question
Seeker5211
Seeker5211
