Question about Emerson Audio Players & Recorders
Idler Wheel on Record Player
I have an old Emerson M2405B turntable. It works, but it's been sitting in my aunts house idle for so long that it appears that part of the rubber on the wheel has gone flat and now there is this constant thumping sound....how can I fix that? Or how do I figure out exactly which wheel i need to buy to replace---i tried to look it up but couldn't get any results. Thank you :)
    Top Expert:
  • Emerson Master
  • 42,925 Answers
That old Emerson turntable is a relic from another era. It is unlikely that you can find replacement parts.
Posted on Dec 27, 2013
4 Suggested Answers
scope eye
  • 4 Answers
SOURCE: Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Posted on Feb 10, 2009
  • 909 Answers
SOURCE: Trying to fix an old record player - Califone.
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
Posted on May 14, 2009
SOURCE: everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Posted on Oct 12, 2009
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
I have a Arvin console record player and the turntable will not turn model 80m46-14 how do I know if it is the belt or idler wheel
The turntable will need to be removed in order to carry out a visual check.
Mostly the process of removal isn't difficult as belts and idler wheel replacement is a fairly routine operation.
Mostly this can be done by removing an "E" clip from the centre spindle. The clip is often hidden by a piece of trim or a circular nameplate which must be removed to gain access.
Feb 20, 2015 | Audio Players & Recorders
Idler wheel
You need to get another wheel.
Dec 27, 2013 | Admiral Dryers
Zenith is4041 record/ cassette player
There is a clip in the center of the turntable's spindle. Remove it and the turntable platter should lift up. That model of turntable is driven by a rubber surfaced idler wheel that is tightly held between the motor shaft and the inside of the turntable's rim by a spring.
Most likely problem(s):
1. The motor is seized. (Even a seized motor will hum, from the 60Hz vibration of its windings.) You should be able to spin it freely between your thumb and index finger, with no resistance. If not, you must totally disassemble it (easy job), clean out the bearing journals with alcohol, lubricate, and reassemble. If you decide just to oil it without cleaning out the bearings, it will quickly seize again.
2. The idler wheel is seized on its shaft. Same solution as 1.
3. The rubber surface of the idler wheel has become hard with age. Best solution for this is to replace it, if you can find one. Alternatively, there are various liquid chemicals around that can renew the surface of the rubber.
4. The pivot mechanism that allows the wheel to assume its proper position is seized. Same solution.
5. Any combination of the above, including all of them! :-)
While you're in there, look at the geared wheel that engages the teeth on the inside center of the turntable's platter. It will have a little "kicker" mechanism that is moved by the turntable's tone arm (part that holds the cartridge) as the tone arm nears the end of the record. This little mechanism is notorious for seizing, and should also be cleaned out and lubricated.
Cheers!
Aug 16, 2013 | Zenith Televison & Video
I have a zenith console turntable and the radio part and speakers work just fine but when i turn the dial to phono all the lights go off like nothing works and the platter doesn't spin
The turntable is probably frozen and needs to be serviced. The platter need to be removed and the old grease removed and new grease applied. The rubber idler wheel may also be hard and it should be soft, This wheel turns against the platter and is attached to the motor. All of this is located under the record platter after the rubber mat has bee removed.
Aug 10, 2013 | Audio Players & Recorders
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
Old zenith turntable turns fine but makes a little noise like there might be something under the table.
Hi, It sounds like you have an ordinary sound. If memory serves correct " ZENITH RADIO CORP." made just record players and changers for use with consoles and uprights. This would put that turntable in the "IDLER WHEEL" drive category. The way to determine if there's any thing to be concerned with is to remove the platter. This can be done by gently removing the "E CLAMP" from the base of the spindle ( what goes throught the hole of the record ) once that is accomplished platter should come right up and off. And as a rule of thumb idler wheel drives in those types of turntables are notoriously noisy. But feel free to examine underneath the platter if you wish-pretty straightforward design as far as how it operates. Feel free to ask for more help, Thanks for choosing FixYa, and I hope this was of some help, Prodzilla
Apr 13, 2011 | Audio Players & Recorders
Feb 09, 2009 | Crosley Traveler Turntable
I have a old antique wurlitzer and the records are playing very slowly what can be causing this
Bad drive belts.
Motor needs servicing (most likely).
Hasn't been converted for 50 Hz.
Dave F.
Nov 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cant get the record to start spinning
The plater is either belt driven or idler wheel driven. You need to remove the plater and check the condition of whichever you have.
Belts would need replaced if bad, sometimes you can clean idler wheels with brake fluid and get them working again. Also if the unit is old, the grease on the plater spindle may be dried up. Clean it off and re-grease. Any light lithium grease is good or go buy some "Luberex" at radio shack.
Geno
Feb 26, 2008 | Philco (R) Classic Turntable CD Shelf...
80 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
