Question about Pioneer Avh-p4450bt 7" Bluetooth Gps Navigation System Ipod Car Dvd Player
How do i reset my pioneer
When i switch on the car head lights, the head unit goes so dark i can hardly see anything...DVD is playing but we see nothing...something has gone wrong all of a sudden...please help
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
SOURCE: amplifier does not turn on when head unit is turned on
Wow guess you dont need help sound like you need a new amp! ohhhhhh wait I changed my name and NOW DO YOU SEE HOW HARD IT IS TO GET A NEW NAME YOU HALF WITT WANNA BE ******???????/ ENJOY AND GOOD LUCK BECAUSE I TALK TO OTHER PEOPLE WITH THIS NEW NAME TO.......HOW MANY NAMES DO YOU WANT ME TO COME UP WITH. i CAN COME UP WITH ONE EVERY THIRTY MINUTES.........HOW MANY TIME YOU GONNA POST A NEW QUESTION............. OHHHHH AND DONT FORGET THE ABUSE BUTTON ON THIS ONT TOOOOO BECAUSE MY NAME ISNT ON THIS ACCOUNT EITHER JUST ANOTHER FREEEEEEE E-MAIL ACCOUNT SOOOOOOOOOOO HAVE FUN AND CRY YA HEART OUT........UNLESS IT IS THE FBI YOU CANT TOUCH THIS AS OLD SCHOOL MC HAMMER SAID.
Posted on Jan 07, 2009
SOURCE: changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Posted on Mar 15, 2009
SmartAviator
  • 449 Answers
SOURCE: Pioneer 1280 changer has no power and won't eject
It can be confirmed by checking.
Posted on Jul 17, 2009
SOURCE: I have a pioneer avh-p6500dvd I was playing a dvd
I have the same problem, it seems that the Integrated circut that controls the CD stoped working.
You'll need to go to a repair shop and replace it.
Posted on Aug 22, 2009
I have a Magnavox dvd player/ vhs MWD 2206. It does not switch between dvd and vhs play modes. It stays on the dvd screen no matter what I do. The light goes on to indicate which is supposed to be in use...
Software issue since unit is not recognizing the tape. Try a hard reset and see if that clears up the cobwebs. U might also check to see if there is something in the vhs tape path that sends a signal to the main board for switchover.
Aug 25, 2017 | Televison & Video
It won't play anything. It just says disc error.
have you tried a DVD/CD player cleaner on it? if it does nothing you may have to manualy take the DVD player apart and clean the laser head
you have to take some Q tips and gently very gently rub the little head on the unit then you should be good to go if not then the head is shot and the dvd player needs to be replaced
Jan 02, 2011 | Philips Magnavox DVD Player MWD200F
Radio and dvd player and brake lights have all
YOU SHOULD HAVE 2 POWER FEEDS TO BACK OF HEAD UNIT, ONE IS SWITCHED OFF IGN AND ONE CONSTENT, WITH THE GALAXY ITS WIRED LIKE A vw/seat SO IF YOU HAVE FITTED A NON FORD UNIT THEN YOU NEED TO SWITCH THE RED AND YELLOW FEED AT THE REAR OF THE HEAD UNT. CHECK YOU HAVE 2 FEEDS GOING TO THE REAR, IF ONLY GETTING 1 YOU MAY HAVE A FUSE GONE, CHECK BOX UNDER DASH AND THE OTHER ONE UNDER HOOD/BONNET
Dec 06, 2009 | Car Audio & Video
When we play DVDs, the picture is very dark and is
Check your dvd settings, read the manual that came with it. Or you can just pump up the brightness on the tv when watching movies.
Anyways, hope this helps.
Jul 14, 2009 | Cyberhome CH-DVD 300 DVD Player
CD changer output not working
There is an obscure setting for 'AUX' on/off that is hard to find unless you know what you're doing or looked in the manual. Typical Pioneer for ya.
Apr 19, 2009 | Pioneer DEH-P3600 CD Player
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
PYLE PLTSD7BT
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jun 28, 2008 | Pyle PLBINDV7 Car DVD Player
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Pioneer Avh-p4450bt 7" Bluetooth Gps Navigation System Ipod Car Dvd Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
