Lg screen cant display. turned off after about 30 mins
I've tried to see if its on auto sleep but the screen isn't just coming up. though the power indicator is on (the red light), the screen still refuses to display even after I press the power button on the remote control.
    Sergeant:
  • 247 Answers
Sounds like its not receiving a Signal, I would try changing your source (VIDEO) cable and trouble shoot the source itself, whats pushing the LG? If its a cable box I would unplug it for about a minute and plug it back in. Test your connection on a dvd or computer to see if it will get an image from another source if it does then the problem lies with your cable company and the box need to be fixed or replaced.... LGs are durable TVS Its very rare that I have to actually go on site to fix one its normally done over the phone because the problem is usally the source not the TV>
Posted on Dec 27, 2013
bestdarngood
  • 3037 Answers
SOURCE: cant get tv to turn on
what color does the light on the front of the tv show and is it flashing?
Posted on Apr 05, 2008
vinnyq
  • 157 Answers
SOURCE: screen displays not available eventhough the video
The main board has become faulty. The logic in the TV is bad that is causing the TV to have such problems. The only way to fix is to replace the main board.
Posted on Nov 09, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
toolkits
  • 1099 Answers
SOURCE: Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Posted on Jul 02, 2010
  • 608 Answers
SOURCE: Tv turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Gen runs when switch in auto even though power avail. Tried resetting ATS - waited 30 min. No luck. Only way to turn off is to move switch to stop/reset. Any ideas on what is broken?
have an electrician check the relay that is activated when the utility power fails
that is what starts the genset when it is in auto
it should also stop the get set when utility power comes back on
Nov 03, 2015 | Kohler 17RES 17 kW Generator
I have an LG 21" monitor. The screen went blank
Without the model number, it is not possible to research this issue. However... My first suspect would be with the software driver. Some system settings do not like to be oscillated too quickly. (I.E.Going in and out of sleep mode for the computer too quickly, or to and from power save for the monitor too rapidly.) This was a problem especially for older versions of windows. (Vista and prior.) Increase power-save to more than 5-10 mins, and check for driver updates. Being that you were able to get it running without unplugging or turning off the monitor, I do not believe it is a monitor issue. (Outside of the RARE possibility of a hardware or firmware conflict between the monitor and video card/chip set.)
Sep 19, 2011 | LG 22" FLATRON LCD Monitor
Tv turns off after 7=8 min.
Sometimes they come automatically on demo mode chesk if in your main menu it has a demo mode it may also have a sleep timer st check that also.
Apr 11, 2010 | LG 26LC7DC 26 in. LCD HDTV
Inside screen cracked??
Hello. Take the phone into the phone store and they will repair it for you. Joe
Mar 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
After 30 mins the screen goes to sleep how can you change the time duration to a longer sleep cycle
If you are running Vista, go to control panel, power options, then on the left side you will see the display options.
Feb 19, 2010 | Dell SE198WFP LCD Monitor
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Foggy screen
get some fogoff at your local hardware store
Dec 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
