Question about Stoves Ovens
Defy manual I need a wire diagram for defy kitchen master DSS 406 oven thermostat.
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have purchased an oven
My Adobe Reader isn't working on .pdf files, but this header on google mentioned your unit, so perhaps it has a wiring diagram:
http://www.google.com/#sclient=psy&hl=en&q=EFG-201+wiring+diagram&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&psj=1&fp=f66f1a25e5eaf8db
If you go to the following website, they have many diagrams and parts lists and wiring schematics for ovens:
http://www.appliancepartspros.com/
Just enter the model number and a page will come up if they have it.
Good luck, and hope this helps.
Posted on Sep 26, 2010
reyjoshua07
  • 1157 Answers
SOURCE: nderwilt@telkowiring diagram for defy 600
Hi dvanderwilt,
For this concern, you need to contact Defy directly since they are the only one who can provide you the wiring diagram for this specific model. For contact information please visit this link. For additional information about your machine you may also visit the link below.
Defy 600
Hope it helps.
Thank you for using FixYa.
Posted on Apr 11, 2011
kebah
  • 683 Answers
SOURCE: We own a Defy Gemini
Visit http://www.macspares.co.za for Defy Masterchef oven diagram.
You can also download owner's manual at http://www.defy.co.za
Regards.
Posted on Jun 16, 2011
  • 92 Answers
SOURCE: need illusrated wireing diagram for 18 year old
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Posted on Oct 18, 2013
Need wiring diagram for defy stove
Do a google search for a wiring diagram for your particular model
Nov 05, 2017 | Ovens
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
My 735mf defy stove has no power showing. How do I fix this?
Check the breaker and the wiring to the outlet. Here is the manual for the stove. Contact the maker.
http://www.defy.co.za/images/manuals/068_366_%20STOVE_731MF-735MF-831MF-835MF-NOLOCK_June2013.pdf
Oct 14, 2015 | Ovens
My defy oven's bottom element heat up although the oven is turned off
Assuming you have not removed or reconnected any of the wires I would look at the thermostat.
Nov 23, 2014 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
Oct 18, 2013 | Ovens
Looking for electric wiring for a defy slimline 600s oven
Gert, dont know if this is too late but I found it on macspares.co.za - left hand column towards the bottom under wiring diagrams
Apr 06, 2011 | Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Ovens Logo
543 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
