Where is the audio jack on my soniq TV model E32Z10B I need to connect to my laotop?
I am using my laptop to view on TV through VGA connection , it works but I need sound.
SOURCE: Audio Jack Problem
check any other driver installed before the current driver......
Posted on Aug 16, 2007
dante777
  • 623 Answers
SOURCE: Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
  • Try to right-click somewhere in the desktop, choose "Properties" and go to the Settings tab. (Now you should be able to see both monitors.)
  • Click on the "Identify" tab to see which one is your TV.
  • See if "Extend my Windows Desktop onto this monitor" is checked.
  • Try to find a resolution that works with your TV by changing the values for the screen resolution.
Posted on Jan 03, 2009
  • 87 Answers
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
SOURCE: connect my laptop to tv with a sound
Your computer may have come with cables to do just that. If not, you have options:
For video, I would check your TV inputs to see if it has a VGA port, since that would be the easiest. You can also get VGA to RCA or S-Video converters online as well if your TV does not have a VGA port. Almost all TV's these days have RCA inputs.
For audio, you can get a headphone jack (3.5mm) to RCA converter.
If you can't find the converters at your local electronics store, just google VGA to RCA and headphone to RCA.
Once you have the necessary cables connected to your TV, your computer will recognize that it has been connected to an external video source. I'm not sure, but I think it is either key combination Fn+F6 or F7 to perform a monitor switch. You can also right-click on the desktop and select properties (or personalize in vista). Then switch to the settings tab (or Display settings in vista) and click on the alternate display.
Posted on May 03, 2009
SOURCE: No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Posted on Feb 04, 2010
Testimonial: "Thank you for the response - will try this and see if it works"
What kind of cord do I need to connect my laptop so Netflix Movies can play on our T.V.?
Hi Candice,
First, without the model of your TV *and* laptop, no one will be able to give more than general information. It is much better to provide too much info than not enough - to get questions answered quickly here. With that said..
The short answer is that you need a cable that will connect to your note book (most likely either Video [yellow], S-Video, VGA, DVI, Display Port or HDMI) and the TV (most likely RF, Video, S-Video, PC / VGA, HDMI or RGB) Only the HDMI cable will provide sound with video. The others will require either an audio connection from the laptop (probably via a 3.5mm stereo headphone output jack) to the TV (most likely standard "RCA" jacks [red & white] - or settling for the laptop speakers or external amplified speakers plugged into the headphone jack.
If you are unable to locate a cable that has the connector supported by the laptop with a connector offered on the TV, it is likely because it is not possible to connect the two (HDMI to video, etc.) with only a cable. Additional hardware (probably expensive if available) will be needed to up or down convert & split audio to make it compatible.
Take a photo of the jacks offered by your laptop and those on your TV to a respected TV / Audio store / department for additional assistance. Some Radio Shack store employees are very good - and some are just plain horrible. Save your receipts in case it doesn't work to your liking.
Keep in mind that a $50 Roku box will stream Netflix (and a whole lot more) to most TV's "right out of the box" - or by buying $10 HDMI cable online to connect an HDTV. Don't spend 20, 30 or more dollars on an HDMI cable unless you want to pay too much!
I hope this helps and good luck!
Oct 22, 2013 | Computers & Internet
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
Connected N130 using VGA cable to tv but no audio
You will not receive audio through the TV you will through the laptop only if laptop is your main source for video. Until you use an adapter to RCA jack Y Tee one input with two output RCA heads on them. To insert into laptop audio to your TV audio. Surround sound system are ideal for doing this with. That is how I have mine hooked up from my laptop.
Special Links for You to View Click Here how to connect Laptop to Video
Apr 12, 2012 | Samsung N13013B Netbook
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
I conect my lenovo laptop Y 410 with Panasonic THP42C10 D for Vidio There are no sound in TV
Hi dr_piyushpat,
I see that you conencted your Lenovo Y410 to a Panasonic THP42c10 LCD TV, see details below.
*The Audio will dpened on what cable connection you have from the Laptop to the LCD TV,
*You have Y410 I do not think that HDMI will be an option.
*I believe that you are using the VGA port on the Machine for an extended Video.
*The Audio will really not be coming out of the Panasonic TV if you are using a VGA cable since that is only for Video you will need an audio cable Jack that will relay audio from the Laptops Audio Jack to the Audio Jack of your Panasonic TV thsi is the only way you can get audio out from the Laptop since you are conencted using a VGA cable.
* do not think that HDMI is present on your Lenovo Y410, but if ever you may have that connection/port the way to get Audio from an HDMI conenction is to change the audio PLayback properties and selct HDMI as the default device for the Audio to work using HDMI.
I hope that this helps.
have a nice day,
mvincentc
Feb 13, 2011 | Lenovo 3000 Y410 Laptop
Can i hook my computer to tv ?
Hello
You can connect your Sylvania LC320ss8 to a computer. There is a socket at the back of your TV to connect it with a PC via VGA cable. One end of that cable must be connected to TV, and the other end of the VGA cable must be connected to PC's monitor out jack.. You have to purchase on VGA cable for this purpose, and is available at most of the electronic spare part shops. A "mini-plug audio cable" also is needed to connect the audio from PC to TV. Its one end to be connected to PCs Audio Line Out jack and its other end to TVs PC in audio jack. Both Jacks can be located at the back side of the TV. After connecting it select the TV to receive PC signals according to its manual says. OK.
Jan 26, 2011 | Sylvania LC320SS8 32 in. LCD Television
Connect a acer aspire to a tv to play films does it have a vga card??
Please check the ports at the bacj your tv if it has a vga-in. If it does, then you can connect a vga cord, then set your laptop to display on external viewing device by pressing Alt+F5 or please see the manual that came with your Acer Aspire.
Apr 01, 2010 | Computers & Internet
How can i connect my advent qrc430 to a hd television
There are two options available with this laptop. Unfortunatley you will not be able to produce a High Definition picture, but nether the less it is possible to connect it to a HD TV.
The connections available are;
1x VGA - You will need a VGA Cable (as long as your HD TV has a VGA/PC input) cheapest found on Ebay. There is also a VGA to HDMI cable. Still wont be HD but an alternative to think about.
1x S-Video (TV-Out) - You will need a S-Video Cable (make sure HD TV has this input) also cheapest on Ebay.
Both of these options do not produce audio through them so for this you will need a 3.5mm audio jack to 3.5mm audio jack. Plug one end into your earphone socket on your laptop and the other end into your HD TV PC Audio in socket/Audio in socket. If you have a Cinema/surround system you will need a 3.5mm audio jack to stereo phono, as long as the surround system has an audio input.
LINKS
VGA to HDMI cable: http://cgi.ebay.co.uk/1-8m-VGA-to-HDMI-Cable-Adapter-M-M-For-Laptop-PC-LCD-TV_W0QQitemZ350312945946QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item519047591a
VGA to VGA: http://cgi.ebay.co.uk/5M-VGA-SVGA-15-PIN-CABLE-PC-TO-TFT-MONITOR-LCD-TV-LEAD_W0QQitemZ330370826650QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item4ceba2c19a
S-VIDEO to S-VIDEO: http://cgi.ebay.co.uk/5m-S-Video-Svideo-SVHS-4-pin-Cable-Lead-Male-GOLD-16ft_W0QQitemZ360181396530QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item53dc7bf432
3.5mm AUDIO to 3.5mm AUDIO: http://cgi.ebay.co.uk/1-8M-3-5mm-3-5-Jack-to-Jack-Audio-Cable-Lead-Wire-Gold_W0QQitemZ270522394462QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3efc64275e
3.5mm AUDIO to PHONO: http://cgi.ebay.co.uk/5M-3-5mm-to-2-RCA-Stereo-phono-Audio-Cable-for-iPod-Mp3_W0QQitemZ250574651547QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3a5769c09b
Hope this helps. If it does please leave a thumbs up....Thank you.
Feb 04, 2010 | Computers & Internet
Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Jun 17, 2009 | Konka DLC-3211UT 32 in. LCD Television
Connecting to laptop.
You have two way to connect your laptop to your T.V. using VGA or S-video, Check your T.V. for VGA (which is standered on all Laptops) and S-video which is on most T.V., but not standard on laptops.
You also will need RCA audio to earphone jacks to get audio out of your T.V.
After you connect your laptop to your T.V. press FN and F5.
May 27, 2009 | GE 25GT240 25" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
