Question about Philips Cineos HTS9800W System
Philips tv troubleshooting
On off switch broken, but can turn on /off via wall. However, red light on TV comes on and takes several attempts to turn on with red light flashing after failing to turn on. Voice comes on for a 1/2 second then off along with red light. any help appreciated
    Top Expert:
  • Philips Master
  • 34,089 Answers
Power supply failure.
Posted on Dec 27, 2013
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
Model:Philips 42PF9965 Plasma At switch on the green light comes on for a few seconds,then it goes off and the red light starts flshing.After several attempts the tv may come on live and stay on until you...
You might have some swollen capacitors on your power supply board. They will be easy to spot out, because they will not have flat tops like the rest of the capacitors. Replace them with the same rating capacitor. You will need a soldering iron, solder and solder wick for this repair. If you are not comfortable with electronics I would recommend taking it to a authorized service provider.
Apr 14, 2011 | Philips 42FD9954 42 in. Plasma HDTV
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
My TV just turned off and the red power light started to blink, why?
In most cases this error will dissapear by switching your television off at the wall and then switching tv on (via power button on TV front/side panel) "Whilst still switched off at wall outlet"
This will discharge all capacitors inside the TV
Now turn TV power button off then switch back on at the wall outelt then try to resume watching TV.
This solution may clear the blinking red light however if it does not it could be a more serious issue such as a blown fuse or even blown control circuit on the TV, In this case you should decide whether a repair is economical or to replace the TV.
This solution is based assumption this a CRT television and not an LCD.
Hope this helps
Feb 28, 2011 | Toshiba Televison & Video
Power cycles when turned off
repeair your power supply again,change some of capacitor or diod and through soldering
Aug 28, 2009 | Polaroid FLM-2601 Television
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SPN4235 TV -- red light blinks but picture doesnt come on.
being that it fell , this is already a bad sign that the screen is dammaged and it will need to be tested and looked at to see what other dammage has happen to it
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Philips Cineos HTS9800W System Logo
149 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
