Question about Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV
Vertical lines on pn50c450b1dxza - Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV
I have a Samsung PN50C450B1DXZA that has horizontal lines on top and bottom it covers 1/3 of the screen, l replaced the Y-con but the problem still there, any suggestions ???
If the horizontal line colors are not black (other colors) then the issue is with the plasma panel itself. If it is black, try playing with the resolution settings.
Jan 29, 2018 | Samsung Computers & Internet
Have a PN50C450B1DXZA Samsung Plasma TV and there are black lines going across the screen.The menu appears behind the black lines.Could the problem be the Upper Y Scan Drive or should I trash the TV?
It appears that the bondings on the plasma panel are giving way. The problem will increase with time and if I am not wrong, you will have to bear with it or change the tv.
Jan 18, 2018 | Samsung Televison & Video
Samsung PN50C450B1DXZA plasma tv manual
Try Googling (Samsung)(PN50C450B1DXZA)(manual) without parens.
Jan 16, 2018 | Samsung Televison & Video
Samsung PN50C450B1DXZA 50" plasma tv works fine other than pink vertical lines on one side of the screen
Generally, any horizontal or Vertical line appearing on the TV screen indicates a faulty circuit. The complex circuit boards can become faulty from age, overheating, or a power surge. Power surges do the most damage, thus it is advisable to always plug the electronics (TV, Computer, etc) into a Back Up Power Supply (UPS) for protection. Naturally the Power Back Up must be relative to the Wattage of the electronic device. Like 1000 Watt for a TV.
As for the Circuit Boards, a technician with test equipment needs to check out what component needs replacing.
Plasma TV with thin vertical lines
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 02, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
Fix vertical lines on plasma tv
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
Model pn50c450b1dxza. Why does vertical line sometimes appear in middle of picture then disappear?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 27, 2015 | Samsung PN50C450 50 in. TV
Vertical lines on left side of pn50c450b1dxza
Line, faults to both LCD & Plasma TVs are given with illustrations. You can get an idea about the fault to an extent.
Sep 02, 2015 | Samsung PN50C450 50 in. TV
Vertical lines in the scree of my 50
Several possible reasons include:
A bad board somewhere in the set.
A communication or Handshake issue--the boards communicate info to the main board and if not proper certain areas of the screen will have lines etc.
A power supply issue is rare for this but possible.
Last but not least the issue could be a defective PDP---Plasma Display Panel (entire front screen unit) which if is the problem is fatal from a cost point of view.
Not likely any of these are going to be either a do it yourself repair or be repaired in the home.
May 03, 2012 | Samsung PN50C450B1DXZA 50-inch Class...
Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
