Question about GE GBS22HCP Bottom Freezer Refrigerator
Freezer icing up
The freezer keeps icing up, and water trickles out at regular intervals, I defrosted but within 10 days the problem started again, I'm not sure about the model, it's GE profile bottom-freezer that bought in 2001
  • 9 more comments
  • pampi Oct 19, 2007
    Model number is TCX18PAARBS. The ice builds up on the back panel and the freezer floor, not the door. I hear the fridge fan running at intervals, but I can't tell if it's inside the freezer (actually, I'm not sure what you're asking). Hope that helps. Thanx
  • Anonymous Nov 15, 2007
    You are not alone, I too have the same model of fridge with the same problem.It started a couple of weeks ago.
    I get a 1/4"build up of ice on the bottom of the freezer - all sloping towards the door, eventualy it does make its way through the tin work or most likely through the door out onto the floor.The only other comment is that the fridge seems to be running/cycling more often.
    The source is triangle shape indent in the back top portion of the freezer
    (which i can only assume has something to do with moisture reduction of the fridge above??)
  • Anonymous Jan 02, 2008
    GE Profile Model #TCX18 or TCC18 (Label removed): Water drips out of the triangular indented thing at the back top of the freezer, running towards the front and eventually running out onto the floor. I can catch it with a jar positioned just right. Worse in hot weather. Would unplugging and letting it "defrost" solve/help the problem?
  • YoHan60091 Feb 27, 2008
    Viking 36" bottom freezer has similar problem. Looked for plugged drain but did not see one.
  • best ever Apr 24, 2008
    Same problem for me... at a certain point the fridge stopped working as well. A defrost brought the fridge back, but now the leak into the freezer has started again.
  • Anonymous May 02, 2008
    Our GE Profile bottom freezer model is TCS18PADBCBS. the inverted triangle simple drips water and eventually the entire bottom of the freezer is clogged and the door will not close properly. I use a spatula to crack and pry the ice out - any solutions? pjburdeaux@aol.com
    thanks, paul
    adsfa
  • jetrepair Aug 16, 2008
    My parents have the same fridge - same problem. I didn't think to take
    pictures until the ice was mostly thawed, but hopefully these images
    can provide a little better insight to our dilemma. Ice accumulates
    until the evaporator fan comes in contact with it and eventually stops
    the fan altogether. while the ice is building it begins to growl until
    it sounds as though an airplane is taxiing through the kitchen. At the
    same time a small glacier forms underneath the fan on the back wall of
    the freezer portion of the unit.
    The repairman said that the drain was likely plugged although he found nothing restricting. Thawing by unplugging seems the only cure so far - any help would be greatly appreciated.
  • Anonymous Oct 01, 2008
    Freezer (Samsung) ices up on inside back and bottom floor. Water trickes out approx one a day. Have tried defrosting but problem persists. The food in the freezer stays frozen.
    Advice on repair would be appreciated.
  • mjd12k Nov 02, 2008
    Model TCC18PACBRBB. Water runs out of the triangular reservoir into the freezer area. Water freezes and has to be chipped out. How can I get that panel open as pictured? I removed the screws but that three inch wide strip in front of the base is a bugger to remove.
  • Anonymous Mar 11, 2009
    I''ve had this same trouble with the GE unit for a year now. It happens on and off depending on amount of humidity present in the house.
    If you do happen to pull the bottom off the fridge part and carefully pull off the styrofoam cover, be careful around those coils as one tiny puncture and your fridge is in for some expensive repairs.
    What I have noticed is that my temp control seems to have become extremely sensitive and if you put to the normal setting of say 4, the unit runs and runs and hardly shuts off. I've cleaned the door seals completely so I know that warm air is not leaking into the unit. And despite all this the drain tube ( made of aluminum) freezes up over the span of about 10 days. Normally  the melt water from the coils, during a defrost cycle, should flow dow that tube and into the pan under the fridge. I can only guess that the defroster heater is not getting hot enough for the right amount of time to actually melt the frost and make it hot enough to melt its way down the drain tube.
    As I have repaired the defrost thermostat in the past I can only suspect that the main thermostat is now failing and that the fridge is running far longer that is should. This may be causing the excessive frost buildup and thus the huge pool of ice from the defrost melt in the bottom of the air exchanger.
    If you do encounter this ice lump in the bottom you will have to slowly melt it until access to the drainpipe is free.
    You can tell if the fridge is freezing up if you hear the blower fan buzzing meaning it is hitting the build up ice.
    Considering that the main thermostat is not working right unless you set it to 1 I may consider replacing that part.
    I hope this helps you understand the problem.
I changed the defrost thermostat and it solved the problem.
Posted on Apr 07, 2009
  • 473 Answers
Need to ask some questions first.  What is the complete model # on the sticker inside the fridge?  Where exactly are you seeing this ice buildup (back panel, door, freezer floor)?  Do you hear the fan running inside the freezer?
Posted on Oct 18, 2007
We have a GE profile bottom freezer that came with our house. The freezer kept icing up evey month or so, shutting the fridge off. After a repair call, my husband copied the repair man and used a blowdryer to thaw it out. Eventually he put a thin piece of styrofoam cut to fit the bottom of the fridge and wrapped in plastic wrap under the crisper drawers. Voila...no problem in over a year now!
Posted on Feb 28, 2010
I had the same problem. I changed the thermostat twice, no help. I called an official service dude. No help, cost me 250 bucks. Here's what I did:
I insulated the back of the fridge with insulating putty (the black curvy pipe). I jerry rigged a scoopula (from basic chem class, long curved aluminum scooper)) and made a little bridge over the drain area with it. Voila, solved the problem. Service guy couldn't. Interestingly, he wanted to buy the fridge off me. Maybe he did not fix it because he wanted to cheat me out of it. You never know, we must trust our fellow human beings though.
Bottom fridge models ****. The veggie bin is too close to the freezer and ends up freezing anything in there except for beer. Buy a top freezer for all the trouble this model is worth.
Without a fridge, there is no society.
Posted on Jul 18, 2009
What to do the ice bridge is too thick
First De-Frost. The same process can be speeded up by opening the Fridge Doors, remove the electric plug from the socket(i.e. switching off power) and wait for all ice to melt, drain the residual water and Re-Start the Fridge.
Regular defrosting(say Once in 10 days) will ensure there is no ice built-up!
Apr 12, 2012 | Freezers
My icemaker is not working.
Hi and welcome to FixYa, I am Kelly.
Often when ice makers slow production or stop making ice it is because the freezer compartmet\nt has warmed up above 17 Def F and the ice maker thermostat will not cycle to start the ice harvest cycle.
In the back of your unit you will have an inlet water valve assembly that will look similar to this one:
Water Dispenser Not Working Check the water supply to the water inlet valve. Check the water filter. ( if applicable)
Check the water inlet valve
Make sure the Temperatures in the Fresh? food section and the freezer sections are normal. 33 to 42 in the Fresh Food section and 0 to 10 in the freezer. Or check that the controls, both the fresh food and freezer section controls are set on the "normal" settings. If the controls are set too cold it will cause the water? tank or tubing to freeze.
Dispenser switch not? working, check for continuity
One side of this valve does the water in the door, the other the water for the ice maker
Disregard any reference to water in door if your unit does not have that capability and there will only be ONE solenoid on the inlet water valve assembly.
If the solenoid coil fails it will not open the water source to supply water to the ice maker. This solenoid is only energized for 8 to 10 seconds as the ice maker sweep fingers (Called ejector blades in the manual) reach the 10 - 11 o'clock position during the harvest cycle. All you will hear is a minor buzz and maybe a minor thump of the plastic water line but the ice maker fills during the last 40 % of the harvest cycle.
Here is a manual you can use for troubleshooting:
Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf">http://www.affordableappliance.com/Download%20Folder/Whirlpool-Roper-Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf
Note the requirements to test the ice maker using the manual above are:
Door light switch plunger depressed (Taped down) and the freezer temp from 0 - 10 deg F.
You will need to make a jumper wire to jumper terminals T to H inside the ice maker front cover to start the ice maker test. If it cycles with the jumper the thermostat is good. If it does not cycle then either the thermostat has failed or... there is no power coming from the door light switch. (Bad door switch)
If all of the system tests pass and you still do not have water.... suspect the inlet water valve (pictured above) or the water supply as the source of the problem.
More often than not.... the real problem turns out to be ice build up on the evaporator coils due to an automatic defrosting problem. Should you discover a build up of ice on your evaporator coils do a MANUAL defrost session by unplugging the unit and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so be ready!) After the manual defrosting return the unit to normal service. You should have ice again within 12 hours. Keep an eye on the evaporator coils for the next 5 days because if you do have an automatic defrosting problem the symptom WILL return in a matter of 2 - 4 days. If the ice block returns.... have the automatic defrosting problem corrected to keep your ice maker working normally.
Thanks for choosing FixYa,
Kelly
Apr 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
Lots of ice & water on the floor too
I would check if the cooling coils and drain in the freezer are frozen. Thaw this ice, especially the ice in the drain. If it happens again within a few days, you need to investigate the defrosting circuit.
Oct 04, 2009 | LG Refrigerators
Repeated ice over the coil
The defrost cycle is either failing to start (problem with defrost timer) or is not heating the defrost coil (most often defective defrost thermostat.)
When you defrosted did you remove the panel at the back of the freezer to defrost the drain hole for the defrosted water to drain out?
Sep 08, 2009 | Jenn-Air JCD2389G Side by Side...
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
FREEZER KEEPS ICING UP
lol.. welcome to my world... I have my fridge set at the lowest without turning it off...IT FREEZES a gallon of tea in 5 days!! My freezer ices some.. its set at 3..(1-6).. BUT I like keeping frozen foods FROZEN.. I deal with the ice...
I have asked several repairmen.. they just guess...I am NOT going to spend money for something that is a GREAT Frig/Freezer.. better than TOO HOT and ruining food!!
Sep 24, 2017 | Amana ARB8057CSL Bottom Freezer...
GE GBS22HCP Bottom Freezer Refrigerator Logo
2,885 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
