Question about Xerox WorkCentre M24 All-In-One Laser Printer
My printer is saying it a fault has occurred and only allows me to access the Scan,menu but the photocopy is deactivated
    President:
  • 2,072 Answers
Have you checked the machine status, then checked the supplies? One of your drums may just need replaced. Of the fuser life has reached its end, the transfer belt or cleaner may have reached end of life. That is the most likely reason you can scan and not copy.
Posted on May 20, 2009
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Printer gets part way through a document and then stops. Printer control indicates printing is complete. This fault appears to occur more frequently when printing on both sides but the faullt occurs about...
maybe you need to change the setting for the paper size that you are using this can be done through the menu that is probably located on top of your printer access the printer portion of the menu and there should be a tab that says paper size change the setting to 8.5 x 11 to use normal printing paper.
Jun 30, 2011 | HP Photosmart 2575 All-In-One InkJet...
My printer is saying "Check
Try this procedure:
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Jan 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
CANON PIXMA MP 130 ink absorber
Hi There
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full
it is problem there many waste ink fall a pad it was most derty then printer call a service
you are a technician you clean it and change new one pad it is like a foam and reset it
Nov 26, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
CF2001 w/Fiery X3A and scanner resolution
How is the scan resolution changed when using the Scan to HDD feature?
Solution
Press the scan button and then press the clear key on the copier control panel. Enter the desired resolution from 1-600 DPI.
Mar 18, 2008 | Minolta CF2001 Copier
Xerox WorkCentre M24 All-In-One Laser Printer Logo
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
