Question about LG 32LB9D TV
How do I reset my lg32lb9d
No picture or sound
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
I have a Mits WS-65511 that the picture lighting started to to fade in and out. We still have sound but the picture is not the right color, fussy and lighting is dim. I did reset the TV, no difference. I...
Three basic color picture tubes in tv are getting weak in performance and requires more current to work properly. There is Screen voltage settings that needs adjustment for each picture tube in tv.
Let me know are you familiar with electronics stuff repair and willing to work in live tv?
Thanks.
Jul 03, 2011 | Mitsubishi WS-55513 55" Rear Projection...
I have no sound on my LG32LB9D
Hello
You haven't specified anything about the condition of picture. So I thinks there is no sound; picture OK; and posts this solution. Check out the speaker first. Just place your ear very near to the speaker side of your TV and switch the TV 'ON', by using its main power ON/OFF control [Not with remote control handset]. If you can hear a 'thumb' sound from the speakers the speaker is OK, and the sound output section inside the circuit board of your tV is faulty. Either sound card or audio output IC may be replaced. If you can't hear any 'thumb' sound when you switch ON your TV, the speaker is faulty. Replace the speaker with samee type and impedence. Its impedence will be marked on its magnet [in terms of Ohms]. OK.
Jul 01, 2011 | LG Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
We have sound but no picture
reset the unit by shortening the battery side...or you you just reset the unit by turning it off and after 10 to 15 seconds, turn it on again
Nov 13, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
No sound
i messed with the menus and now i have a picture but no sound
Jul 20, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Getting my pictures off my phone
try this tricks and codes,
you can earase Pics. by selecting the MEDIA
*2767*63342#
All sound and Pics will be deleted.
Tips & Tricks For Samsung :: You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone.
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
Dec 22, 2007 | Samsung SGH-d807 Cellular Phone
LG 32LB9D TV Logo
27 people viewed this question
Computer Repairing
Computer Repairing
