Question about Toshiba Satellite P105-S6177 Notebook
Toshiba MT7 after 5 min it turn off automaticly
Toshiba MT7
Reset BIOS password in Toshiba AIO DX1215-D2101
just remove the cmos battery for 5 min. press on button 3 to 4 times., it will automatically reset.
or
remove the bios jumper and fix it to 2nd and 3 rd pin., start the machine .and stop it.after wards replace it to original position.
1st method is easy.,
Apr 13, 2015 | Toshiba Computers & Internet
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
TV automatically turns off. unpluged the tv and
Hey i am having the same exact problem with my same exact tv. If you have already solved your problem I would love to know how u did it. I know you posted this a long time ago but if you havent gotten it fixed yet, if I fix mine i will let you know. Thanks.
Aug 03, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Automatically shutting off after about 5 min
dose it have a thermostat if it dose that will turn it off
Jun 24, 2009 | Comfort-Aire PAD-91 Air Conditioner
TOSHIBA SATELITE 215 NOTEBOOK HEATS UP.
One quick and easy fix you can do is to go get a can of compressed air and blow out the vents and fan area under the notebook. Sometime when there is a lot of dust in them they overheat pretty quickly and shut off. Just like you said happens.
May 21, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba wireless gets disconnected automatically
Is the signal strengh strong?
Are you using the correct password if you are usiing one?
Try resetting the router or access point if possible.
Install the latest wireless driver to see if its corrupted:
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
choose your model from the list.
May 11, 2009 | Toshiba Satellite A215-S5837 Notebook
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Mar 31, 2008 | Toshiba e-Studio163 Copier
Laptop prob
Check to see if the CPU fan/cooler is clogged or not working. Laptop could be shutting down to keep the chip from frying.
Feb 22, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Oct 28, 2007 | Toshiba 36A43 36" TV
Toshiba Satellite P105-S6177 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
