Question about Acer Aspire R7
Screen doesn't turn on - Acer Aspire R7
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
My display screen doesn't work and the camera turns on but would not turn off
Hello, Sounds like internal malfunction, needs to be checked by service tech.
Dec 16, 2012 | Kodak EASYSHARE M1063 Digital Camera
Doesn't start anymore
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.If this doesn't do it please reply to this post and we'll go on from there.
Apr 18, 2012 | Texas Instruments TI-84 Plus Calculator
My ti 84 plus does not want to turn on, i thought it was battery problem so, i bought new batteries but i stil have a blank screen.
Could it be that your screen has been dimmed in error. Turn the calculator on & press the 2nd key and then the up arrow. This darkens the screen.
If this doesn't work, try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 21, 2011 | Texas Instruments TI-84 Plus Calculator
The touch screen doesn't work
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
May 09, 2011 | LG KS660 Cell Phone
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
Samsung YP U5AB- all files in device accidentally erased. Now the computer software doesn't recognise the device.
my samsung YP-U5AB/MEA is not working when i'm turning it on , the screen doesn't turn on but when i put it on the computer i can save things on it but it doesn't work ....help please ???
Feb 20, 2011 | Computers & Internet
Replace LCD screen on Kodak m853 camera
KODAK doesn't sell spare parts. An OoW repair for this fault is 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 09, 2008 | Kodak Cameras
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire R7 Logo
143 people viewed this question
Top Acer Sport & Outdoor - Others Experts
Bill Eager
Are you an Acer Sport and Outdoor - Other Expert? Answer questions, earn points and help others
