Question about Canon FAX-JX200
Error check 5100
Check 5100 how to remove this problem
  • Canon Master
  • 808 Answers
Error 5100 refers to the encoder strip not being read correctly.
Open the main cover so you can see the carriage (The print head, where the ink cartridges are). While it is moving you must pull out the power lead so it stops mid-travel .with no power you can move the carriage easily. Slid it to the left. You can now see the encoder strip. Its a thin translucent strip running the full width of the machine. I had black lines in it. I suspect it is dirty and wants cleaning with a cotton bud soaked in water. Run the bud along as much of it as you can. If dirty the bud will come out in dark blue. Now dry the strip with a dry bud. BE CAREFULL. do not apply any amount of pressure on it as it can break very easily. It is spring loaded. Move the carriage back to the right side. When it was on the left there may have been a wheel also of the same material up against it. Clean the round strip in the same way. Hopefully that will get it going again.
Posted on Jan 14, 2014
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Error message 5100
Http://www.ehow.com/how_6527399_fix-error-5100-canon-i860.html
plz click this link
and find the instruction how to remove this error
Jan 14, 2013 | Canon PIXMA iP6220D Photo Printer
5100 error message
Hello and Welcome to FixYa!
Error 5100 means that the cartridge can not be detected by the printer
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
To solve these follow the following steps. I hope it works
  1. Turn off printer
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I get a service error 5100. What is this and how do i fix it? i changed ink cartridges and then got this error. it seem the cartridges only fit one way because i tried to reverse how i put them in.
Hello !
Service error 5100 is a carriage error. Be certain that the strip is remove from the cartridges. Check the timing strip for contamination (plastic strip about 1/4" in width)
Check for obstructions. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt. There could be paper caught underneath the rollers. Check VERY thoroughly.
Hope this helps.
Oct 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error 5100
5100 = a carriage error
*** ALWAYS DISCONNECT POWER FROM WALL BEFORE WORKING ON MACHINE***
Check the timing strip for contamination(plastic strip about 1/4" in width). The unit is not homing, check for obstructions.
Clean the inside, check your ink cartridges and make sure they are properly installed ( if not they may stop the carriage from moving properly) and then turn off and back on.
Jan 21, 2009 | Office Equipment & Supplies
Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Sep 01, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Service error 5100
Error 5100 is either a logic board, or
the code strip (if that is the problem) is another matter -
It is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will give this error, also if it has any ink,
grease or other foreign matter on it, it will give errors.
You can clean it with a cloth dampened with water but you need to exercise
great care to avoid pulling it off its anchors.
The other thing to do is clean the stainless steel bar that the carriage sli
des
on and lubricate it with a cloth moistened with 3-in-1 or light machine oil.
If neither of these works then I guess it is repair shop or replacement time
Nov 03, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon FAX-JX200 Logo
57 people viewed this question
old marine
old marine
