Question about KitchenAid 24 in. KUDS02FR Built-in Dishwasher
What causes a kitchenaid kuds02fr to stop working and blinking
Can I replace the white front panel & handle with stainless steel?
I'm not sure about the handle, that may be a manufacturer part. But I know Appliance Art has alot of different options including stainless panels and faux stainless as well. www.applaianceart.com
Dec 28, 2010 | KitchenAid 24 in. KUDS02FR Built-in...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have a Kitchen Aid model#KUDS25SHBL1 and it leaks through the bottom of the door. What is the cause and how do I fix it?
There are two things that could cause this issue. The first and most common is a cracked feed tube. The feed tube is the plastic pipe that sits under the upper rack and feeds water to the middle spray arm. If this tube breaks or cracks it shoots water directly down toward the front of the door and leaks occur. The part number for a new tube is 3378144
The second thing it could be is the lower door seal, it clips onto the inner door liner at the bottom. It is part number4172127
Jul 13, 2010 | KitchenAid 24 in. KUDS02FR Built-in...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water is leaking on to the floor from the float
please change the 'o'ring for this please call the service engineer.
Nov 07, 2009 | KitchenAid 24 in. KUDS02FR Built-in...
Film on dishes after washing
try running a package of Tang drink crystals through the machine. empty into the soap dispenser and run with no dishes in it. see if this will help.
Oct 04, 2009 | KitchenAid 24 in. KUDS02FR Built-in...
All lights blinking on my blender
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available.
This error was probably not caused by replacing the coupler, but merely coincidence.
You may find a Kitchenaid certified service location using the following link:
http://caservice.kitchenaid.com/
If this is not helpful, I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Nov 28, 2008 | KitchenAid KSB5 Professional Stainless...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid 24 in. KUDS02FR Built-in Dishwasher Logo
57 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
