Question about Cajun Injector Electric Smoker XL with Glass Doors
My Cajun Injector electric smoker with glass doors did not have an owners manual. Where can I get one?
No owners manual in the box
Where can i buy replacement elements for the cajun injector smoker
Sorry we do not have parts locator services here.
Sep 04, 2017 | Cajun Grilling
Why wont it heat up
sounds like a bad thermostat check the probe wiring and make sure theyre not touching then check to see if they are grounding out anywhere (touching metal with a bare wire) if thats not the problem replace the thermostat
Mar 30, 2016 | Cajun Injector 01939 Electric Smoker
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
Where can I find the Owners Manual for a Outer Electric Smoker?
I could not find a manual for your Outer's Smoker however, most electric smokers are preset to have a heat output between 225*-250*. The smoker should have a smoke box that sits on top of the heating element. Preheat your smoker by plugging it in, then add wood chips to the box with your food on the racks.
There is a great blog that has a forum dealing specifically with smokers (with a section on electric smokers):
http://www.smokingmeatforums.com/f/
or
http://www.smokingmeatforums.com/f/110/electric-smokers
Good Luck!
Jul 14, 2014 | Grilling
Thermostat is stuck on 387 degrees. How can I fix it?
I had the same problem. Readout showed 330 degrees, but it should have been 60. Saw all the bad reviews on this product after I started to research this problem, so I figured I would try to fix it. I drilled all the rivots out of the back panel. There are 2 thermocouples, 1 for the meat probe and 1 for measuring the temp inside the smoker. Both thermocouples have connectors in about the center of the smoker. I cut the wire on both sides of this thermocouple and spliced them together without the connector. Works fine now.
Jan 11, 2014 | Cajun Injector 01939 Electric Smoker
There are no perforations in the smoker box lid. Do I leave it off while smoking?
No, do not leave the smoke box lid off. Smoke will escape thru the seams of the smoker. This is normal. If necessary, you can adjust the door hinges to allow the door to fit tighter.
To help you, in case you have misplaced your Owners Manual. I have included a link to it, that you can download and print for future reference.
http://www.masterbuilt.com/pdf/manuals/07092010%2020070910%20Manual.pdf
Jul 09, 2011 | Masterbuilt 20070106 Electric Smoker
I need a replacement heating element for a Cajun injector electric smoker
Hi, replacing heating elements can be found at amazon, click here and take a look: Save Time Money and Energy with Induction Cooking. I hope this helped you. Have a nice day
Oct 21, 2010 | Bruce Foods Cajun Injector Creole Garlic...
Cajun Injector Electric Smoker XL with Glass Doors Logo
121 people viewed this question
Top Cajun Injector Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Cajun Injector Hardware and Accessory Expert? Answer questions, earn points and help others
