I have tried to hook up cable and dvd to my big screen, but nothing is working. I even tried going through the "set-up" options. The only thing I can think of is, the A/V part of the setup is on "none". It will not let me go to basic or advance options within this part of the set-up.
Any ideas or solutions would be helpful.
~thanks~
Although this is an old post I will try to answer it the best I can.
As long as you have hooked up your cablr/dvd onto the right tuner ( tuner a/tuner b.etc ), it should work if you go to the menu and turn on that tuner. ( ie: if you hook the tuner to tuner A, open up your menu and find where it asks which tuner you are choosing to use and click on tuner A ), then the set should work. If this doesn't straighten up the problem, you may have a bad processor on the main tuner board. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
