Question about Kenmore 98702 Stacked Washer/Dryer
My washer loads water and than just locks up had a hot smell, if i shake or change load it runs
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
YOUR MOTOR IS ON ITS WAY OUT
Posted on Dec 27, 2013
SOURCE: Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Posted on Apr 26, 2008
  • 958 Answers
SOURCE: Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Posted on Oct 02, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Posted on Feb 25, 2009
  • 11 Answers
SOURCE: My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Posted on Mar 24, 2009
SOURCE: My HE2 front loading washing machine smells
remove the front bottom panel.
there is a trap down there just before the pump. mine was a cylinder with a handle to unscrew the cap/filter.
clean this out every 6 months..
Posted on Aug 25, 2009
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I find the source of the sour water smell and remove if from my washer?
that smell is usually caused by a build up of soap and residue from normal laundry,, a simple way to fix this is to run a empty full load add 2 cups of vinegar to the load, it will help in the breakup of buildup in the machine,, after that ,, run a load on Hot to drain out any left over vinegar
Jun 13, 2011 | GE WJSR2070B Top Load Washer
Odors, the machine smells very much like mildew
Cure 2 cups of bleach large load water setting, hot water let set 2hrs full of water run washer empty "no clothes just hot water" 2 times normal wash setting, repeat if nessary.Note : Not all of the water drains from a washer the water left in yours spoiled, bleach should take care of it.
Nov 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
We have a Kenmore washing machine, model 82984120, purchased in 1991 and have never had a problem. We have begun getting a foul smell after we finish washing. When I shake the basket, I can hear a bit of...
THERE IS ALAWYAS WATER PRESENT IN THE WASHER DRUM, RUN A LOAD OF HOT WATER WITH 3 CUPS OF BLEACH IN IT THIS SHOULD KILL THE MOLD THTAT IS CASUING THE SMELL, USE THE HIGHEST WATER LEVEL SETTING, DO IT TWICE AS NESS.
Sep 06, 2009 | Washing Machines
My clothes never have a good smell or at best any smell recently. I also never see the water stay in the washing and it suds up like it used to. It appears that when the water is being put in, it is going...
Try this. Run a load of a few towels with no soap, no bleach, no fabric softeners. Set wash water temp to hot. After hot water enters and begins to wash, stop the washer and open the door. Pour in one cup of vinegar (white is fine.) Run the entire wash cycle.
-Buy a supply of High Efficiency Washing detergent (marked "HE") and do not over fill the detergent cup (use a little less than the directions say, never more.)
-Buy a name brand supply of fabric softener with a scent you enjoy and can recognize.
Run the next weeks loads of wash (no need to use Hot water any more) and report back here with how things are smelling. OK?
Aug 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer smells musty
there could be buildup in the outer tub causing some water to stay trapped and causing the smell, try running some loads uning Ahfresh or you can try pouring lots of bleach in there and letting it sit a while, then run it throu a cycle.
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Stinky washer
I have the same problem. The solution is to use bleach with your whites. It's better to use a normal amount of bleach frequently rather than a lot of bleach only once in a while.
Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
