Question about Airforce Welding Tools
Hobart 250A cuts but when trigger is released there is a delay before starting again
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: Plasma cutter only cuts for only a few seconds
The unit needs to be tested.
You're welcome to ship the unit to me for diagnostic testing and repair. info@taeckertindustries.com
Posted on Nov 07, 2009
  • 242 Answers
SOURCE: cuts in short spurts does not stay on
sounds like a boad problem or a relay playing up.
Posted on Dec 31, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
My hobart handeler 125 will not stop feeding after i release the trigger, why?
The trigger is bad in the gun. It sound like the spring is bad, or you have some junk in the trigger not alowing it to release. Remove and inspect/clean the trigger.
Nov 04, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Nov 07, 2009 | Airforce Welding Tools
Hobart 250ci quit working
Provided Air is between 60 and 80 psi (common operating range).
Power is measured to be in range as per label or manual specs.
Replaced all consummables on the torch head.
Usually the next step is to change the Torch Head. After all else fails this is usually the problem, especially if the torch head became hot while cutting.
Apr 10, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Jan 22, 2009 | Hobart Welding Tools
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Welding Tools Logo
43 people viewed this question
Top Airforce Welding Tools Experts
Bill Boyd
Are you an Airforce Welding Tool Expert? Answer questions, earn points and help others
