Question about Depo Auto Parts Toyota Corolla CE/LE/S New Radiator Cooling Fan Assembly-Shroud Blade Motor 2003 2004 2005 2006 2007
Using skyfi3 in older used car
I own a skyfi3 xm radio that I have use in my 2002 ford escort. Recently however I was in an accident and said vehicle was destroyed. I am now searching for a used vehicle. I havent listened to regular radio in Milwaukee for some time. when using the skyfi3 I connect the xm radio to its dock and the dock to a power adapter near the gear shift select lever. I have recently looked at several older vehicles and I am wondering if it is at all possible to connect my adapter to a power outlet in older cars. Tomorrow I am going to look at a 2003 toyota Carolla ce. will I need to cancel the subscription or can i fit may adapter in the cars power outlet to make it work.
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Oct 01, 2010 | Delphi SKYFi3 XM Radio Receiver
I have a XM delphi skyfi3 and I can record songs and listen to the radio portion fine. However, I cannot play my recorded music back on the my music mode, regardless of whether the xm is in the cradle or...
You must have a subscription and listen 'live' 8 hours a month, or it doesn't let you listen to recorded content anymore (thanks to the RIAA and their royalty fees to XM)
Jun 27, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
I just bought a 2gb MicroSD card to put in my device. I need to know what menu settings i need to change to record songs onto the card instead of the internal memory on the device
The bad news is, because of the RIAA and royalty rules, you never are able to record from XM onto the MicroSD card. All you can do is playback your OWN MP3 files that you've put on the card. Also, you will LOSE all your recorded XM songs from the SkyFi3 when you don't listen to XM live anymore after a month; so complain to the RIAA and all the record labels that made this stupid rule.
PS: Make sure you've updated your FIRMWARE from the XM or Delphi website. Good luck!
PSPS: Does your SkyFi3 add a 1/2second blank inbetween songs when you record continuously and the song title changes?
May 25, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
The Skyfi3 receiver will "self-mute". Is the mute frequency the same as other phone devices or TV remote controllers? I have the Skyfi3 in the kitchen, could an appliance cause this?
Yes, if you mean XM reception. Your microwave oven is actually a radio transmitter near the Satellite Radio frequencies and when you use your microwave, it WILL wipe-out XM radios. Even my neighbor can do it to mine! Check it out - boil some water and watch your signal fade in and out! You're going to want to move the radio, or use a 'repeater' for it, or use the playback of prerecorded.
Oct 29, 2009 | Delphi SKYFi3 XM Radio Receiver
Delphi SkyFi3 Battery WIll Not Hold Charge
You can buy a whole radio for as little as $30. I would even call XM and tell them you're going to cancel because your radio died, and they might sell you one if you guarantee to stay with them for a year?
Aug 02, 2009 | Delphi SKYFi3 XM Radio Receiver
My xm skyfi3 is on and the buttons will not work It is frozen up and I cannot get it to turn off or do anything. I have checked the button lock switch and it is off
Try this: "Reset your SKYFi3 by pressing and holding the volume button and pressing the mode button" (from user guide page 62)
Dec 13, 2008 | Delphi SKYFi3 XM Radio Receiver
Depo Auto Parts Toyota Corolla CE/LE/S New Radiator Cooling Fan Assembly-Shroud Blade Motor 2003 2004 2005 2006 2007 Logo
41 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Todd Arndt
Todd Arndt
Kar Volk
Tom Chichester
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
