Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Rise in the Temparature & Processor Fan's Speed
My processor temperature has been increasing also the processor fan speed up if i m playing some games r watching videos   Processor Family : INTEL Pentium 4 Processor 515 2.93 Ghz Speed    : 533Mhz L2 Cahce    : 1MB
  • 818 Answers
Games and graphics place a huge demand on the RAM (memory) and processor. It is for this reason that gamers buy expensive video cards with huge amounts of RAM inbuilt into the card (The cards are almost computers in their own right).
Your processor has to deal with a lot of information when you watch dvds or play games .. it works damn hard ... hence the heat .
Your best option is to fit an additional cooling fan (computer shops have them in stock). Try removing the side of the computer casing to allow more air to circulate. Die-hard gaming enthusiasts add all sorts of extras to their computers .. water tubes to circulate water .... that sort of thing.
Your processor will become hot .. that happens in all computers. It's EXCESS heat you want to avoid. As a general rule of thumb, a processor's ideal temperature is 40 degrees C, though they do go beyond this temperature at times, without adverse effect.
Posted on May 18, 2009
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
Tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 | Computers & Internet
What is the processor fan speed for Dell Vostro A860?
This could be the result of to much dirt build up in the heat sink ports blocking vital air flow. Buy a can of compressed air and blow it on fan any open ports, this should prove if the fans the issue, the speed should slow down because of increase air flow cooling the laptop. If this works the machine should be taken apart for better clean out.
Mar 06, 2012 | Dell Vostro A860 Notebook
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
The computer chassis with the chassis intrusion feature installed and enabled has been opened or the chassis intrusion alert has been cleared. The processor temperature is too hot and the power supply has...
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Sep 01, 2011 | Dell OptiPlex GX620 PC Desktop
My acer turns off as soon as it turns on. I changed the battery and now it stays on but the screen is black and the light for the motherboard does not light up ?? nothing happens
Check status of your grab loader,it may be due to grab loader failure.
Also check the ststus of your windows,they might have corrupted.
Also scan your system for virus infection.
Due to virus infection, fan speed might have gone changed,which can lead to overheating and rise the processor temp.
Hence check your fan speed and processor temp also through BIOS.
You can control fan speed through BIOS.
May 14, 2010 | Acer Aspire 4520-5141 Notebook
Latitude e6500 runs hot how do i boost the fan
You may need to clean the fan and heatsink of dust. See the dust restricts the cool air from reaching the heatsink and this in turn causes your fan to spin faster. The computer's BIOS is programmed to increase CPU fan speed as CPU tempreature increases. If your fan is very loud, then it is running at the maximum speed possible. A clean heatsink will decrease the Processor's temperature.
Installing additional fans in your computer's chassis is an effective way of bringing the temperatures down. Install the biggest fans that your chassis supports. 120mm fans are better than 80mm fans as they can spin at slower speeds to provide the same airflow of a smaller fan. Therefore giving you a quiet computer.
Use a program called Speed Fan to ensure that your fans are indeed running at the desirable level of 100%
Take care!
damnor01
May 12, 2010 | Dell (6F858) Cooling Fan
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
Still want to shoot into a thermal runaway.
First of try to understand exactly what part you mention exactly how they work or function
  1. please place a new low speed relay as it try to make out thermal heating cool at it's initial 1st stage level of heating so that the temperature remain maintain if thus it reaches the second level of heating then the high speed relay act at that time & the speed of radiator fan increase to get thermal heating in control.
  2. the thermostat regulate the heating temperature of the engine it senses the temperature & signal to the relay the relay then react according to the temperature level of engine at low heating it operate the low speed relay & high temperature it signal to high speed relay so the engine temperature does not rise to extended level of heating or overheating.
  3. see for thermostat valve is failure if that so replace it new sometime most of the mechanic change it or cancel it so that the temperature does not rise as this thermostat help engine maintain it's ideal temperature which is required by the engine for regular or good working even at extreme climatic condition.
  4. Do check for every tensioner or Ideal Bearing as far consider on the No. of miles or Km the vehicle has run according to us the tensioner or ideal bearing are suppose to be replace at an interval of 30000 to 35000 Km. but this replacement include both Engine timing belt & tensioner & ideal tensioner bearing.
  5. A water pump flow depend on the tension of the drive belt some vehicle come with water pump which drive on inner timing belt tension & some on the fan belt or external tension belt of engine.
for further more FAQ do send in or place your problem we will sort it out till then have a safe drive & happy motoring from siddhanth.....!
Sep 29, 2009 | 2003 Chrysler PT Cruiser
Intel D865GBF hangs for error thermal event
The solution to your problem can be found at this webpage : http://www.intel.com/support/motherboards/desktop/sb/CS-012552.htm.
It guides you on how to solve overheating problems. Personally I think you need to unseat your processors and refix after cleaning and applying a fresh coat of the Heat Conducting Paste and re-seat it very, very carefully. Gently in the beginning and once u are sure that it has got into its slot smoothly then press harder until u hear two cliks, like a double lock. Fix the Heat sink &see that the retaining clips are snug tight. Try it & post the results........sodeep
Quote "High Temperature Alerts
If Intel Active Monitor or Intel Desktop Utilities alerts you about temperatures above set thresholds, there are a number of steps you can take.
Check for proper airflow:
  • Make sure the processor and chassis fans are running.
  • Check the cabling; make sure cables are not interfering with proper airflow through the chassis.
  • Check that nothing is blocking airflow into and out of the chassis' airflow vents. This is common in direct airflow systems (BTX). Chassis manufacturers may apply a dust filter in front of the CPU fan inlet. Check that the filter is clear and free of dust buildup.
  • Make sure that the air intakes for the external fans are unobstructed and are located at least several inches away from walls and other items.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Consider adding another chassis fan.
Other troubleshooting steps:
  • If your PC uses an Intel® Pentium® 4 processor in the LGA775 package, be sure the heatsink is properly installed and 'locked'. Pay particular attention to the proper orientation of the locking pins and give a good push down on the pins (sounds like a double click) to lock them into place. For complete processor and heatsink integration information, refer to Boxed Processor Installation.
  • Verify the chassis/case and power supply are appropriate for the processor model and frequency and the motherboard you are using.
  • Verify the thermal solution for the processor is adequate for the processor and frequency of the processor.
  • Make sure the processor fan cable is connected to the correct fan header (specifically for the processor). Refer to your motherboard documentation for more information.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Update the system BIOS to the newest version. This will often correct problems with how the system measures temperature.
Fan Control Behavior Changes after BIOS Updates
After updating to the latest BIOS version on certain Intel Desktop Boards, the CPU fan may not go to full speed operation until the processor reaches about 72°C (162°F) and all system fans go to full speed at 75°C (167°F). You may see temperature alerts in Intel Desktop Utilities.
Previously, certain processors' thermal values were not available to the BIOS so the BIOS was unable to perform the appropriate fan control (the fans ran at 100% constantly). With recent BIOS updates, the thermal values are available and the BIOS will run the appropriate fan control. This means the processor may reach temperatures of up to 75°C (167°F) before the fan will go to full speed. The fan control now allows processor temperatures to rise to optimal levels while the slower fan speeds improve acoustics.
Setting Temperature Thresholds in Intel® Active Monitor or Intel® Desktop Utilities
By default, the temperature thresholds in the hardware monitoring software are set as follows: Zone Intel® Active Monitor
Intel® Desktop Utilities (ver. 2.0.11.46 and earlier)
Intel® Desktop Utilities (ver. 2.1.8.63 and later) Processor 75°C
(167°F)
75°C
(167°F)
75°C
(167°F)
Zone 1, Zone 2, or Motherboard Zone 50°C
(122°F)
50°C
(122°F)
65°C
(149°F)
If you've checked for proper airflow and performed the other troubleshooting steps listed above and you still consistently receive high temperature alerts in any of the temperature zones:
  • If you are using Intel Active Monitor, you may increase the temperature threshold. You can safely increase the Zone 1, Zone 2 or Motherboard Zone threshold up to 60 Degrees Celsius (140 Degrees Fahrenheit).
  • If you are using Intel Desktop Utilities version 2.0.11.46 or earlier, upgrade the software to the latest version, which sets the zone default thresholds to 65°C.
  • It is not recommended that you increase the Processor Zone threshold.
Downloading these utilities:
Intel Desktop Utilities".........unquote"
Feb 19, 2009 | Intel D865PERL Motherboard
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
292 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
