Question about Panasonic Computers & Internet
Phoenix bios setup utility password
Passwored
SimpleText
  • 9 Answers
SOURCE: phoenix bios password
A direct way to blank out a BIOS password would be to remove the CMOS battery for a bit; I'm not sure where that would be in that particular laptop but commonly it is a small round flat battery
Posted on May 28, 2009
  • 3940 Answers
SOURCE: Forgot Phoenix Bios Setup Utility password.
You can bypass the password, but it does require contacting Dell to get the information:
http://www.fixya.com/support/r3656360-dell_portable_computer_bios_hard_drive
Posted on Feb 07, 2010
SOURCE: how to set up phoenix Bios setup utility for main:
I HAVE PROBLEM WITH MY ACER TRAVELMATE 2410
I HAVE FORGOTTEN THE PASSWARD FOR THE PHOENIXBOIS SETUP
Posted on Mar 13, 2010
  • 8 Answers
SOURCE: Acer travelmate 2410 phoenix bios setup utility
u got to replace ur BIOS. but der r ways to recover the BIOS password using default passwords, i need to get to know ur MOTHERBOARD build.
Posted on Mar 31, 2010
melaiii
  • 35 Answers
SOURCE: Phoenix bios setup utility is requesting a password
Actually, if you do not know the password it is best not to guess because 3 wrong guesses would result to losing the data on your hard drive forever.
the simplest way to remove a bios setup utility password is by removing the cmos battery. computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
1. open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. please refer to the picture below. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
2. Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
3. Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
Posted on Apr 14, 2010
Whaat is phoenix bios setup utilitiie and whats the password
You may be able to access the bios using one of these backdoor passwords for the phoenix bios
BIOS
CMOS
phoenix
PHOENIX
Or you may be able to reset the bio password using this utility.
http://www.cgsecurity.org/wiki/CmosPwd
Mar 30, 2015 | Toshiba Satellite Computers & Internet
What is the Phoenix Trustedcore(tm) Setup utility password
If it's a BIOS password, ask the person that put it in. OR, contact the the Laptop Manufacturer for a one-time BIOS password.
Apr 13, 2013 | Computers & Internet
I can't get into my acre aspire one laptop it's
http://dogber1.blogspot.com/2009/05/table-of-reverse-engineered-bios.html
http://www.biosman.com/bios-password.htm
http://www.ehow.com/how_5268844_reset-phoenix-bios-password.html
Nov 14, 2012 | Computers & Internet
Forgot the password for phoenixbios setup
You need to contact your pc manufacturer.
Tell them to provide you with the steps to remove and reseat the CMOS battery.
Then remove and reseat the CMOS battery which holds the BIOS password.
This step will remove the password.
Issue is resolved :)
Jun 18, 2010 | Advent Netbook
Mar 31, 2010 | Acer TravelMate 2300 Notebook
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
May 28, 2009 | HP Pavilion dv1000 Notebook
Phoenix BIOS password
If u need to change the BIOS settings? then only erase it otherwise keep it as it is.
Jul 29, 2008 | Toshiba Satellite A135-S2386 Notebook
Fujitsu Siemens s7110
Try these, they have been known to work as master passwords for your BIOS:
phoenix, PHOENIX, Pheonix, CMOS, BIOS, 1234567, or xinoehp
Mar 28, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
13 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
