Question about Polaroid Tablet Computer PMID701
Internal decoder error
I can not connect to the radio I keep getting internal decoder error
How do i fix my ipad?keeps saying .. ipad not set up and that needs wifi but it still doesnt work,????
Connect to computer with iTunes on it and try a reset if that doesn't work do a restore...you will lose your data. If that doesn't work your iPad is probably suffering from an internal error and needs repair or replacement.
Aug 15, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Can't connect to WIFI -- keep getting an authentication problem
It depends on the tablet that you have. Usually non branded tablets tends to have lots of problem. It also could be that the radio could be corrupted. Radio is what it take care or manage the wifi, data, etc... anything with connectivity.
I do suggest that your try to flash the radio again if possible. If not, try these next steps:
1. Go tot he wifi connection and tap on forget, this is to make sure that you don't have any wifi saved.
2. Reboot your tablet.
3. Now search for the wifi again, set it up with all the requirement, like password, channels, etc.
4. Wait until it display saved even if it doesn't connect.
5. Reboot your tablet.
6. Try to connect again to the saved wifi. If it still doesn't connect, your only option is to flash the radio band.
Dec 29, 2015 | Tablets & eReaders
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
My nobis 9" tablet keeps popping up windows saying unfortunately blah blah has stopped working. i turned it off and turned it back on and now i can't even get the home screen. please help
Nobis 9 tablets are defective. Many, if not most, of them end up having bad internal memory. They might work for a week, a month or maybe even two months but, sooner or later, theminternal memory goes bad. When this happens you get the stopped working error messages and in many cases it will no longer boot up. Just Google, Nobis NBO9 stuck on go and you will see you aren't the only one who got ripped off when you bought this POS.
I know, I have one. I sent it in when the internal memory went bad. Cost me 20 bucks postage. They fixed it and sent it back. It worked about two weeks and the internal memory went bad again. Then they gave me the runaround and refused to issue me an RMA.
Stay away from anything sold by Bidwell that uses the Nobis brand. Better yet stay away from Bidwell period. They are rip off artists, IMO.
Apr 07, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Tablet won't let me open anything. Bought from a garage sale and she reset it and now it won't work. I tried opening google play and it still wouldn't connect
Because you keep getting "an internet connection error" it sounds like it is not connected to the internet. I would try to address that problem first. I would go in and delete the wifi connection and re-add it using the correct network name and passphrase for your wireless access point. I think that once you get the internet connection error to go away, you will have better results with internet-dependent functions like the app store. Also make sure you don't have airplane mode or other feature activated that would turn off the wifi.
Nov 26, 2014 | Tablets & eReaders
Internal service error
possibly needs firmware updated. Manuals and firmware from here
Manuals CURTIS INTERNATIONAL
May 07, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
Feb 28, 2014 | Android 4.0 Tablet PC
Wont go to log in and internal keyboard stopped working
It seems the system keeps busy starting up, checking and loading drivers for internal hardware or it tries to connect to something, but keeps on waiting for confirmation that it's found.
While undergoing this process, the operating system doesn't get a chance to load the software/drivers for your keyboard.
If there's a reset-button to return to original firmware, try to go for this. If this is not possible, you might have the option to use an flash-drive including the Android-version for you tablet and booting, re-installing Android from it, back to your tablet.
Oct 18, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Polaroid Tablet Computer PMID701 Logo
29 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
nexrad_chris
WTF Chuck.....
WTF Chuck.....
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
