Question about BOSS AUDIO SYSTEMS BV9970 Car Video Player
My boss dvd 9500b screen doesnt work
The music plays but there is no display on the screen what could be the cause?
Cant see my display screen its really dim
make sure your illumination wire isnt connected to a power source other than lights.
Dec 04, 2012 | Boss MP3-3130R CD Player
Screen is blank
check the wiring again for the illum.(usally the orange wire) make sure it is hooked up and dash lights are on high.
May 09, 2012 | Alpine IVA-W505 Car DVD Player
Hi i have a boss dvd in dash 996b in a 2002 nissan altima....always worked good ..i wired the pink wire to the fram to ground out ...always worked...i open dvd to watch movie and display shows NO VIDEO...
have you tried a different video input such as a video input behind the radio. have you made sure that you are playing dvd and not video in. or the boss unit could be broken.
May 05, 2011 | BOSS AUDIO SYSTEMS Car Audio & Video
I have the Boss BV9560 and was wondering what format i need to use to play YouTube music videos on the player, I am using a usb it seems like i have tried every format and it keeps saying unsupported if...
The music format is only support MP3, WMA, MP4, and the video you can use FLV or AVI, I think you need to convert your youtube music video to AVI format, maybe you can try to use Leawo Video Converter.
Mar 10, 2011 | Boss BV7200 Car DVD Player
Wont play dvd or cd on screen displays reading...
Try giving it a dvd lens cleaner and running it 4 or 5 times, if previous owner was a smoker, the lens may be begrimmed with tar, especially if the cd player wasn't used much. If that doesn't work then the lazer diode is probably shot and needs replacing.
Jan 19, 2011 | BOSS AUDIO SYSTEMS Car Audio & Video
I have the boss BR-900CD and everything seems to work fine but nothing shows up on the screen. It lights up but no data shows up. Thanks
the problem is from the display IC of your unit. You nee to change the display IC for your unit to display again.
If you cannot do it yourself, maybe you should consult an expert to help you have it fixed.
Good luck.
May 13, 2010 | Music
I HAVE THE BOSS BR-900CD AND EVERYTHING SEEMS TO WORK FINE BUT NOTHING SHOWS UP ON THE SCREEN. IT LIGHTS UP BUT NO DATA SHOWS UP. THANKS
If all other controls are working, check IF they have a "Contrast" setting for the display. When those are at end of range, the display often is blank.
Mar 21, 2010 | Boss Music
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
BOSS AUDIO SYSTEMS BV9970 Car Video Player Logo
26 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
