Question about Tascam DP-008EX Pocketstudio Digital Multi-Track Recorder 8-Track
How to import music on sd card - Tascam DP-008EX Pocketstudio Digital Multi-Track Recorder 8-Track
Is there anyway to import mp3 music files from my cellphones sd card to a coby MP-828-8G?
I think the easiest way would be to fit the SD card into a USB adaptor and plug the adaptor into the USB port of a computer. If you computer doesn't have a USB port, several printers have them and you can access that port when the printer is linked to the computer. Some printers will even take the SD Card direct! Once connected the Card will be just like a drive. And you can copy the MP3 files to your computer, then import them to the MP3 player.
USB SD Card adaptors are not expensive and can be found on Amazon.
Aug 20, 2014 | Audio Players & Recorders
How to transfer music to tracfone lg 500g
To transfer files to a phone, you can use an android transfer assistant, which allows you to export and import data between phones and computer.
MobiKin Assistant for Android Windows Version
Jun 06, 2017 | LG 500g TracFone
I wanted to check the amount of storage left on my zoom h4n sd card. I went into the sd card file via the zoom h4n menu and it asked me if I wanted to format the sd card. I tried to select 'no' but the...
You may try some recovery software to rescue the files on your handy recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the recorder in case the original files(your recordings) are overwritten.
Apr 19, 2010 | Zoom H4 Handy Recorder
How can you import pictures in inbox on cell phone to the microchip SD 2gb inserted in phone?
Micro SD cards for cell phones are now costing less and are holding more memory. 4GB SD cards can hold an estimated 1000 songs, over 13,000 images, or 22 hours of video individually. 2GB memory cards hold roughly half those estimates and 8GB SD cards would hold double. So if your cell phonemag-glass_10x10.gif has a SD card slot learn how to utilize this expandable memory option on your device. Follow these steps and you will soon be enjoying your music, pictures, and video on your phone!
  1. Insert your SD memory card adaptor (with micro SD card inserted) into your SD Card drive on your computer. This should open a "Secure Digital Storage Device" or similar window. If not, go to "My Computer" to locate your SD card and open it.
  2. Step 2 To transfer picture files to your SD memory card, open the folder or file that your pictures are stored on. Simply click and drag a file or multiple files and drop them into your SD Card window or folder. You can also copy a picture and then paste it to the SD Card.
  3. Step 3 To transfer music files to your SD memory card, open your "My Music" folder. Select the folder where you are going to get the music from (Itunes, Yahoo Music...). Click, drag, and drop the files into the SD Card window or copy and paste them in.
  4. Step 4 To transfer video files to your SD memory card, open your "My Videos" folder. Select the folder where you are going to get the video from. Click, drag, and drop the files into the SD Card window or copy and paste them in.
  5. Step 5 Take out the SD memory card adaptor from its drive. Remove the Micro SD card (small chip for your phone) and insert it into the SD Card drive on your Blackberry, IPhone, or other compatible cell phone.
  6. Step 6 Go to your media, picture, or music folder in your cell phonesmag-glass_10x10.gif menu. Select which item you are looking for and your files will appear!
Nov 14, 2009 | Cell Phones
I have a sd memorie cared and i put music on there and it dosnot want to show up on my phone. how can i get it to work
Maybe you are copying the music in the other folder of your SD Card, try to make a music forlder on your SD Card and copy it again.
Oct 01, 2009 | LG VOYAGER VX10000 Cellular Phone
Can SD Memory cards be used with my Go 720??
the "no SD required" is just letting you know that all of the important stuff to make the unit run is all on the hard drive of the unit itself. Yes you can use a SD card to hold maps, photos, or music. For instance if you were going to Europe, you will be able to get a European Map and download it onto the SD card. Another instance would be if you wanted to download some mp3 files.
Sep 28, 2009 | Tomtom GO 720 GPS Receiver
EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Jan 01, 2009 | Cell Phones
Importing music...
Now a days you are getting latest Mp3 players with Micro SD card fecility. Buy them and copy the mp3 songs from computer to Micro SD and shift that from mp3 player to your lg phone. This works fine.
Dec 18, 2008 | LG Vu CU920 Cellular Phone
Putting music on cell phone
MUSIC
This menu needs to be supported by mini SD Card.
It plays the music stored in the mini SD Card.
Copy the downloaded music from PC to mini SD Card,
and play the music stored in the mini SD Card through
your mobile phone.
Store music in the mp3 folder on the SD card.
1. Press [MENU] .
2. Scroll through the downloaded music to display the
music you want.
3. Select the music you want to play then press
[PLAY] or press [MENU]. Then select “Setting”,
press [OK], then 1.All Repeat, 2.Repeat,
3.Random.
Press [OK].
  • “mini SD Card” is connected to your phone, press
[MENU] to select 1. Setting, 2. Erase (Erase This/
Erase All), 3. Information.
Mar 30, 2008 | Audiovox CDM-8940 Cellular Phone
Transfering MP3's from an SD Card
Putting Music On Your PS31. Make a folder called MUSIC (capital letters), and place all of your MUSIC in there. (You are not required to make a MUSIC folder.)
2. Now connect your device(SD card,Memory Stick Duo).
3. Go to "MUSIC" find where it says "Audio CD", USB, PSP, Memory Stick etc. and press "Triangle" > "Import" or "Copy" if you don't see the files press "Triangle" > "Display all"
Dec 13, 2007 | Sony Playstation 3 (PS3) Console
Tascam DP-008EX Pocketstudio Digital Multi-Track Recorder 8-Track Logo
70 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
