Question about Delta Faucet Delta T4738-SS Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev
Replace delta rp40668 diverter - Delta Faucet Delta T4738-SS Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev
3 Suggested Answers
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
  • 13 Answers
SOURCE: Can the pull-down diverter on a Delta RP17454 be repaired? Does the spring-loaded diverter screw on, or is it glued from the factory?
Probably needs a new washer.
Posted on Mar 15, 2012
My single handle Delta T&S valve doesn't deliver water to the hand held shower when I pull down the spout diverter.
The spout diverter may be corroded and unable to divert the flow completely. I had one job where the spout had to be replaced to get the diverter to function.
May 27, 2018 | Delta Home
Need rough in dimensions for delta R11000
Wondering if you have you model number confused; the Delta R1100 is a shower flow diverter; see here:
diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641">http://www.faucetdirect.com/delta-r11000-3-6-setting-diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641
The installation guide and spec sheet is available for the above on the web page.
Currently available Delta Tissue Holders can be seen here:
http://www.deltafaucet.com/bath/accessories/filter.html#11051218525_
None of the model numbers are close to what you have provide. Perhaps you can pick out the model closest in appearance to yours. Links are available below each model for the dimensions and installation instructions.
Mar 01, 2011 | Delta Faucet Company Innovations Polished...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
My delta faucet pull down diverter tub spout is
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Delta Faucet Delta T4738-SS Lahara Two Handle Roman Tub Trim with Hand Shower - with Lev Logo
59 people viewed this question
Top Delta Faucet Home Experts
john h
bobalix
bcas6924
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
