Question about Atlantic Technology System 170 System
Subwoofer rattle I have a set of Atlantic Technology System 250 speakers. All of them work great except the 252 powered Bass Module. When Bass gets loud the Woofer rattles and sounds disgusting. Can anyone tell me if this rattle can be fixed or eliminated. I had sent it back many years ago to AT for this problem and they said nothing was wrong but I have had this rattle for years now and I just keep the woofer on very low to stop the rattle. Any help with this problem is greatly appreciated. Bill
  • 104 Answers
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
Posted on May 23, 2009
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
I have a proton satria 2007 model with a fully intergarted head u
First off, change the front speakers with a decent pair of aftermarket. Buy a powered subwoofer. One that has the amp built in. Connect it to the rear speakers. Bazooka tubes are great, compact, great bass.Adjust your radio so that the front speakers do not recieve alot of bass,you want it about half way. That way you are using all the power to push high notes, Bass takes a lot of power to push, reducing the volume. Turn the subwoofer to the maximum setting, and then adjust the system to your liking. It will take some time, but it is worth it in the end. Tip: set it while listening to your favorite station. Stations broadcast at different sound levels. Some pump up the bass, some don't.
Apr 15, 2010 | Car Audio & Video
I have hooked this up to a working reciever that
Fill in the blanks about the working receiver.
You mention another subwoofer, which suggests your receiver manages the bass and possibly sends most or all of it to the sub.
If it's NOT sending the bass to the speaker terminals you use to drive the AM5 that would explain it's virtually silent bass module.
If those speaker terminals on your receiver can be set to LARGE, do it. Otherwise they assume the speakers are incapable of handling bass.
Apr 02, 2010 | Bose Acoustimass 5 III System
When i play certain bass, like mainly highs, but not all highs, my speaker seems to rattle. no im not an idiot. i know subwoofers rattle stuff when you have them on. i know almost all there is to know...
It is possible to overdrive a speaker beyond what it can handle.
DO NOT BELIEVE the spec sheets regarding power and capabilty, especially those for automobile amps and speakers.
If the cone moves too far, the voice coil leaves the active area of the magnetic field and the speaker will "rattle".
The speaker AND its enclosure may be resonating at particular frequencies.
If these things are happening, you will permanently damage the speakers.
Jul 29, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Home Theater Subwoofer rattles
Sounds like the controls have a buildup of dust on them and creating a magnetic charge and thus noise. Radio Shack sells "Tuner wash" Use it sparingly, it only takes a little, then work the controls back and forth for a few seconds and turn back on. You may have to do this a couple times to fully clean the potentiometer (vol control) (crossover control) Take the knobs off the unit before you spray it. If you have a high gloss finish on the sub, put a rag around the control to keep excess wash off the plastic. It will varnish a gloss finish. Just use it carefully. Hope this helps
Jun 22, 2009 | Atlantic Technology System 170 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Apr 02, 2007 | Pioneer VSX-D514 Receiver
Atlantic Technology System 170 System Logo
424 people viewed this question
Top Atlantic Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Atlantic Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
