Question about Acer Aspire Computers & Internet
My touchpad can not click after a spill.
I have spilled tea on my keyboard. My touchpad can move but I can not click anything. Can my touchpad be broken? Also my keys are sticky; is there a way I can clean my keyboard? I have a Aspire 7750Z.
  • 35 Answers
Your keyboard is scrapped......go to the nearest service center.....(if you have a warranty) this wont be covered in the warranty you have.
Posted on Dec 27, 2013
azz949
  • 55 Answers
SOURCE: Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Posted on Jan 25, 2009
  • 101 Answers
SOURCE: keyboard doesnt function properly
It is possible that the keyboard matrix is shorted so when you use the external kbd it still gets the same errors. See if you can disable the main kbd in bios and if that solves the problem. You could also try removing the main kbd and see what that does. Otherwise you probably have a motherboard problem. The touchpads are usually pretty tough to liquids - check the cable on that.
Jon
Posted on Apr 13, 2009
  • 1244 Answers
SOURCE: My son spilled Soda on his Gateway laptop. I
yes it is from gateway website!!
Posted on Jan 17, 2010
  • 561 Answers
SOURCE: spilled coke on my keyboard, how do we clean it
Hi
Thank you for your query
Best thing would be to get a damp cloth and simply wipe over the keyboard when the laptop is switched off, this will remove the stickyness.
Please ensure when wiping that no water travels into the keyboard which may cause you problems
Posted on Mar 08, 2010
  • 406 Answers
SOURCE: acer aspire one 10.1 inch netbook. how to clean
  • Moist a towel with warm water. It's just a case of wiping it off
  • Also Make sure that the computer is off.
  • You can also use alcohol-based cleaners, just make sure they will not go near the screen, they are sensitive to these materias
Posted on Jan 14, 2011
Spilled tea on keypad of macbook now it doesn't work
Open laptop and lay on heavy towels with the keyboard facing down, remove charger and main battery, most of the tea should drain out in this position, contact a service centre to assess the motherboard, sooner the better.
Jun 17, 2012 | Apple MacBook Pro Laptop Computer with...
Spilled icetea on to laptop keyboard, will power up but nothing else screen is black. hp nc4200
Ugh, sorry you had the accident, but many a laptop has survived such a spill (or in my case spills) and booted to tell the tale.
I'm assuming you now have the machine powered off, if not shut ot down immediately and do not try to restart it until you have done the following. There is kind of a standard procedure for laptop spills that I will provide you.
The suggestions below assume that your nc4200 is no longer under warranty.
Remove anything attached to the machine, battery, cables, external drives, anything. Using a soft, slightly damp (yes damp - got to remove as much of that sugar as possible) cloth blot any liquid on the machine gently, do not rub.
Tilt the laptop gently from side to side to allow any possible liquid to drain out. Do not shake the laptop. The Place the laptop upside down so that any potential remaining liquid will drain out. Hopefully you did not spill this amount of tea 8^).
Secure a regular hair blow dryer. Set it to low and slowly move it back and forth over the keyboard from about six inches and do the same for the rest of the machine, focusing attention to the openings that it has for ventilation. Do this for about five minutes or so.
Now the hard part: Set aside the machine in a warm (not hot place) and wait (at least four hours and if you can wait overnight, even better).
Try booting it with nothing attached. If it still doesn't boot the problem has gone beyond the keyboard and you'll have to consider having it professionally serviced.
Good Luck and thanks for using Fix Ya
Mikeyaf
Mar 17, 2011 | Computers & Internet
I have Windows 7 on a Dell Inspiron lap top. My
Update the driver for your Keyboard/Touchpad. Got to Dell's Download Page. Enter your Service Tag, underneath your laptop, to get the correct list of drivers for the corresponding model of your laptop. Make sure to select the correct operating system. The touchpad drivers are located in the Input Device Drivers section, listed as Dell Touchpad / Pointing Stick, Alps - Driver or Synaptics - Driver.
After installation, go to the Windows 7 Start or Orb then in the
type main.cpl, click main.cpl in the list of programs.
1. Click the Dell Touchpad tab.
2. Click Touchpad Settings.
3. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
4. Uncheck the box to the left of Tap to Click.
5. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
6. Click Apply, then click OK.
7. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 16, 2010 | Dell Inspiron 1525 Notebook
Got tea on my laptop
As i understand, the system seems to be working fine after the spillage ... there shouldnt be any issues other than the keyboard being sticky .
If the tea had seeped in then it could have fried the Motherboard. However , you could reach HP for support incase of any issues , if you tell them that the tea was spilled on the system then they might not cover the issue under warranty.
Apr 02, 2010 | HP G60-120US Laptop
Spilled tea on keyboard, dried & blew out with dust remover, 4 keys still don't type
try to clean it again with rubber alcohol, tea has sugar which doesnt just go away with dust remover!, if its not working then its being short circuit cuz water is electricity conductive and u need replacment.
Feb 18, 2010 | Toshiba Computers & Internet
My wife spilled tea on her Dell Inspiron 5100. Now when attempt to start up goes to a black screen with blinking cursor and beeps incessantly. What does this mean, and can I fix it?
add milk!
well spilling tea on the keyboard has most likely fritzed the circuit The beeping and blinking, depending on the number of beeps relates to no monitor and no keyboard.wich seems to fit your description of the fault without having to count
As for fixing it yourself? I wouldn't attempt it.. too many levels to wade through and an expensive fix. anyway. cheaper to buy a new one
Try making a claim for a replacement on your home insurance as a fusion claim. ge3t a new laptop. Perhaps the brands that was used at the Olympics that can sustain dropping and water spills. Vario I think it was.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Dell Inspiron 5100 Notebook
I spilled tea on my packard bell easynote
Two things to check.
Open the laptop up and re-connect the keyboard connection. It has a locking mechanism so be sure to unlock that first. Also when you're doing that you can see if there's any water (tea) still in there to dry off.
If that doesn't work, then plug in an external keyboard mate, cause the only other way to fix this is to replace the keyboard, the parts to open up the laptop keyboard itself are intricate and it's much too compicated, plus I've never done that (Seeing as that it's all glued together).
Hope this helps, be sure to rate!
Jan 03, 2009 | Toshiba Satellite M45-S165 Notebook
Mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Feb 20, 2008 | HP Pavilion ze2000 Notebook
My tea just spilt into the keyboard, can i fix it? I spilled tea with a little honey in it onto my keyboard last night. Initially it worked, then repeated a keystroke or two; now it isn't operable. Blue...
You could try removing the keys out of the keyboard and cleaning it with a damp cloth and a can of compressed air. If the tea hit the circuitry of the board though you may have to get a new one.
Dec 04, 2007 | HP USB Wireless Keyboard/Optical Mouse...
Computers & Internet Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
