Question about Kyocera Copystar CS-1620 Black and White Copier
C-6 ( 400 )
He dear my copy machinecyocera is KM-1620 it has error C-6 (400 ) please let me know the simmulatio of that
by regards
  • sayed_mas404 May 18, 2009
    dear sir .
    Copier machine name is ( cyocera KM-1620 )
    Error code is C-6 ( 400 )
    please let me know me the simmulatio mode .
    By regards
KEY IN 1087 TWICE N PRESS START, ENTER CODE ERROR EG.400 N PRESS START. ONCE IT SHOWS CLE, ENTER 163 N PRESS START. WAIT FOR IT TO RESTARST. LALI.
Posted on Jan 27, 2010
    Problem Solver:
  • 8 Answers
400 means laser unit, cleaning or replacement is needed
Posted on May 26, 2009
How do I fix C-4 on KM-1620
please switch off the printer and switch on the printer and check it
May 28, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
When i try to photocopy it always shows c-6 400
try entering 1087 1087 then 163 then 01 to return to normal copy mode. This code can come up when machine loses power while turned on. this will reset the fuser which is probably causing the code.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Error 6 400
replace the fuser and update the firmware
May 12, 2013 | Kyocera Copystar CS-1620 Black and White...
Cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
I have a problem in power code 400 c-6 in km-1620. i have press 1087 continuously but i still have the same problem again.
press 10871087 then 163 then press START 5 times .machine will restart. if problem is still there then u have check ur fixing .might be one of the heater rods is not glowing or the thermistor is blown
Jun 30, 2011 | Kyocera Copystar CS-1620 Black and White...
HOW TO SOLVE J41 IN KYOCERA KM 1620
This is a jam error code check the exit sensor replace if faulty
Mar 01, 2011 | Kyocera KM-1510 Copier
Which numbers can i press when i get error c-6, 400 om a KM-1620 photocopier?
Put the machine on and press 1087, 1087 until the display shows U000. Press 163 and the press start .display shows CLE, press start again. The machine will initialize and become ready for copying
Nov 15, 2010 | Kyocera Copystar CS-1620 Black and White...
Photocopies displays and error message that reads 400 then C-6
It most likely can be reset over the phone. Go to www.gfbm.net and call. They can walk you thru reset over phone whach should correct the problem at no charge.
Jan 14, 2010 | Kyocera Copystar CS-1620 Black and White...
Kyocera Copystar CS-1620 Black and White Copier Logo
1,025 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
