Question about TAMOR CORPORATION Home
Storage container with attached lid that lifts up
Was looking for a 30 to 35 gal container with attached lid. a lid that lifts up
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: Breville food processer Large containe mis
Hello there, there are various breville food processors. Which is the exact model you own?
Posted on Aug 07, 2011
I am looking for plastic containers in portion sizes to fit inside my lunchbag for work.
Compartmentalized BPA-Free Plastic Food Storage Containers w/Easy-Open Lids (Not Leakproof) http://www.easylunchboxes.com/products/food_containers/index.htm
May 09, 2013 | Home
How to unjam the lid to an OXO Good Grip Pop Container
replacement parts can be found easily on amazon. here: Amazon com OXO Good Grip Pop Container parts I hope this was helpful. Cheers
Mar 20, 2013 | Oxo Good Grips POP Rectangle Storage...
I need a new lid
I Found it!!!! http://www.bergandirectdelivery.com/replacement-parts/stack-n-stor-lid
Feb 25, 2013 | Blitz Bergan Stack-N-Store Dog Food...
Pump repair
Instructions1 Unplug the electrical cord of the washing machine from the electrical outlet before attempting to repair the water pump.
2 Turn the water supply off at the shut-off valves behind the washing machine by hand.
3 Press in on the end caps of the washer while pulling forward to remove the caps from the control console and locate the screws in the front of the console on each end.
4 Unfasten the screws on the control console with a screwdriver and flip the console back so that it rests on the rear hinges.
5 Unplug the lid switch connector from the top of the dryer near the back, lifting the plug off the metal prongs by hand. Use a screwdriver to pry up the metal clips that are holding the top on the dryer.
6 Lift the top lid off the washer base, set the top out of the way, and locate the water pump at the bottom of the cabinet on the motor shaft.
7 Slide the metal clips off the top of the water pump with a screwdriver and remove the pump from the motor shaft.
8 Place a plastic container underneath the water pump to catch any water from the pump and detach the hoses, unfastening the clamps with a screwdriver.
9 Remove the hoses from the pump, allowing the excess water to drain into the plastic container, and remove the pump from the washing machine.
10 Attach the hoses to the new water pump, securing the clamps with a screwdriver. Place the new pump on the motor shaft, sliding the metal clips back over the pump.
11 Take the plastic container out of the washer cabinet, disposing of the water. Place the top lid of the washer back over the cabinet, securing it with the metal clips on the top.
12 Plug the lid switch connector back into the top of the washer near the back, attaching the connector by hand. Flip the control console back down over the washer, securing the console with screws on the ends.
13 Fasten the end caps back over the control console by hand and turn the water supply back on at the shut-off valves.
14 Plug the electrical cord of the washer into the electrical outlet.
THanks
Apr 02, 2012 | Whirlpool LHW0050PQ Front Load Washer
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can't locate cooling fan relay
look under the hood and u will find a black box containing fuses and relays lift the top of the black box and look inside the lid for the correct relay location. hope this will help you!!!
Apr 15, 2010 | 2001 Dodge Grand Caravan
Show me how to install new ink cartridge onv305
hi eileenoreill,
you can try these steps:
  1. Turn on your printer.
  2. Lift the scanner base unit.
  3. Press down on the ink cartridge lever to raise each ink cartridge lid.
  4. Remove the old ink cartridge.
  5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
  6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
  7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
  8. Snap each lid closed.
  9. Lower the scanner base unit until it is completely closed
  10. Snap each lid closed.
just update me if the issue is not yet resolved.
Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
How do you open the stove lid of a Kenmore 7907138 five burner gas range? I need to clean it.
You need to be careful with sealed burner ranges. If you try to lift the range top you can damage the alluminum gas pipes for the burners under the range top. Check to see if the burner heads lift off. If the burner heads are held on by screws make sure you remove those first. With the heads removed look down into the cooktop thru the hole where the burner sits. Make sure the orfice is not attached to the lid. If they are you may see a screw you can remove. Look for any other screws behind the oven door that may be attached to the lid. Apply light pressure when trying to lift the lid. If you feel any major resistence DO NOT FORCE IT UP. Sears.com also has parts schematics for every range they make and that will visually help with the dis-assembly because you can see how the parts go together. Also MAKE SURE YOU UNPLUG THE APPLIANCE AND TURN OFF THE GAS VALVE BEFORE WORKING ON IT!!!
Sep 05, 2009 | Kenmore Kitchen Ranges
Where are print cartridges located in the Lexmark 1200 series so that I can change cartridge? Got printer at a sale and don't have manual.
I have a Lexmark X1270 and this is probably the same as yours.Lift the top (not scanner lid!) and with power on the cartridge containers will locate centrally for you to access,once located these coloured containers have a hinged lid,pull the lid upward to remove cartridges contained within.Hope this helps.
May 11, 2009 | Lexmark X1270 All-In-One InkJet Printer
BTS out door Installation
I have no idea about how to install the actual device but I have read and tried mounting equipment out of doors and have these suggestions. I would get a rubberized food storage container that the item will fit into and a lid would close on it without problems. No gaps in the lid. I would cut only the holes I need for the connections to the item, put the item in the food storage container and take silicone caulk to seal around the holes used for the wires to connect to the item. If you had to cut a bigger hole for a large connector on a cable, use household window screen to fill in the hole around the cable and then use the silicone to coat and attach the screen to the food storage container
Much good luck.
Nov 10, 2008 | Computers & Internet
Home Logo
64 people viewed this question
Top TAMOR CORPORATION Home Experts
Donni Steen
Tom Chichester
Are you a TAMOR CORPORATION Home Expert? Answer questions, earn points and help others
