Question about Casio FX570ES Scientific Calculator
How to find the median, lower quartile for Casio fx-570ES Plus?
5 Suggested Answers
SOURCE: what function of remove saved memory of casio
shift 9 3 = does the job
Posted on Dec 20, 2009
  • 7993 Answers
SOURCE: i have filled my data
Once you have filled a list, you can sort it.
As on the following screen press F6 to SET the graph type.
Use the F6 key to cycle through the options.
Press the keys to select the appropriate TAB at the
bottom of the screen. Select Histogram or BOX
Pressing the 1-Var tab at the bottom displays the statistics.
Press SHIFT F1 to trace the graph. Use right or left arrow
to display Xmin, Q1, Med, Q3, Xmax
Posted on Jun 29, 2011
  • 7993 Answers
SOURCE: how do i sort out random numbers?
Here is a sequence of screen captures that illustrates how you do 1-var statistics. I believe it is clear enough.
To sort tap EDIT and select Sort (ascending)
To perform 1-var stats Tap CALC and select one-variable.
Specify the list where the data is (list1), if you have repeated entries you should create a frequency list ( in L2). If no frequency list, frequency is set to 1.
Once you get the stats you can scroll down to read Q1,Q2, Median, etc.
Posted on Apr 14, 2012
  • 7993 Answers
SOURCE: where is antilog function in Casio fx-570ES PLUS?
A name can bring a lot of confusion. The decimal logarithm has an inverse function which is raising a number to a power of 10. It shares the same physical key as the logarithm LOG.
Posted on May 16, 2012
Hi,how can I calculate median using fx-570es plus?
The median is the number is the middle.
Using the calculator, you can follow the Statistical Calculations (Stat) on pages 22 and 23 of the attached manual. http://support.casio.com/pdf/004/fx-570_991ES_PLUS_E.pdf
However, it might be quicker to just put the numbers is order from lowest to highest and pick out the number in the middle.
For example, take the numbers 3, 5, 4, 7, 6, 4, 9.
Putting them in order, we get 3, 4, 4, 5, 6, 7, 9
There are 7 numbers so we want the 4th number (3 numbers to the right and 3 numbers to the left). In this case, the 4th number is 5 and that is our median, as half the numbers are lower than it and half the numbers are higher than it. It the number of numbers is even, you take the average of the two middle numbers.
Good luck,
Paul
May 16, 2016 | Casio Fx-570es Scientific Calculator
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How to do plot and whiskers in a casio fx-115ES calculator
This is not a graphing calculator, so you cannot perform a box and whiskers plot.
If you know how to find the Median(=Q2), the lower (Q1), and upper (Q3) quartiles, you can draw your box and whiskers plot on a piece of paper.
Jul 21, 2014 | Casio FX-115ES Scientific Calculator
Quartile
The first quartile is 4, the second quartile (median) is 8, and the third quartile is 12.
Apr 23, 2014 | Office Equipment & Supplies
Fx 570es or fx 570es plus
Get the Plus. It adds a few functions, takes nothing away, and is the same price at most vendors.
Sep 04, 2012 | Casio FX570ES Scientific Calculator
Where is antilog function in Casio fx-570ES PLUS?
May 15, 2012 | Casio FX570ES Scientific Calculator
I want thousand seperator in my answer in casi sceintific calculator fx570es plus
Sorry, the fx-570ES Plus does not have the ability to insert thousands separators into numbers.
May 11, 2012 | Casio FX-115ES Scientific Calculator
Five number summary
The distribution of the ordered observation is divided into five summaries. That is, minimum, first quartile, median, thrid quartile, and maximum.
Formula:
Minimum = first element of set, First Quartile = (n+1)/4, Median = (n+1)/2, Third Quartile = 3(n+1)/4 and Maximum =last element of set.
May 08, 2012 | Texas Instruments TI-30 XIIS Calculator
How do i sort out random numbers?
Apr 13, 2012 | Casio ClassPad 300 Calculator
I have filled my data but i cant get my median, upper quartile, lower quartile, top and low help??
Jun 29, 2011 | Casio FX9750GII Graphic Calculator
Casio FX570ES Scientific Calculator Logo
535 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
