Question about LG Flatron F700P 17" CRT Monitor
No width hello, the monitor that i did repair cannot adjust the width. what was the problem?thanks
Halooo
Posted on Dec 24, 2007
SOURCE:
I have a old CRT Proview monitor. It has developed a problem of exceeding display sidways, means the display from left and right side of screen goes beyond, I have adjust manually left and right to view...
Well, if the adjustment buttons don't work, then probably the control unit in the monitor is broken, or a key is stuck. If the control unit needs servicing, I doubt if it's feasible to have it repaired, given the fact that it's an old monitor and new or used nice slim LCD monitors can be purchased cheaply nowadays.
Jul 24, 2011 | Proview Computers & Internet
I m using acer moniter,i got the probs with its screen display..width of the screen is expand until max n now pic doesnt look good because width is wider then its height...can u pls assit me how to decrese...
You need to set the PC VIDEO resolution to the native resolution of the monitor to get correct aspect ratio (not adjustable at the monitor, the adjustment is doen at the PC VIDEO card setting), you need to find that out from your monitor owner manual.
Mar 22, 2010 | Computers & Internet
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Nov 27, 2009 | HP Compaq FS 7550 17" CRT Monitor
Width is short
You will need to 'Auto Adjust' your sreen
Jul 16, 2009 | Computers & Internet
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
Nov 17, 2008 | IBM E54 15" CRT Monitor
Width problem
500G CRT LG MONITOR WIDTH PROBLEM
Oct 10, 2008 | LG Studioworks 563N 15" CRT Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
How do I adjust my monitor?
1)Press Menu button once to get the Main Screen Of Menu
2) Select the option which you need to modify (Ex. Brighness)
3) Now again press Menu button to get into that sub menu (Brightness)
Jun 01, 2008 | Computers & Internet
Width problem
Your monitor comes with an internal program that will adjust the monitor. You might just need to update your video drivers, but if all else fails, just get it repaired by the manufacturer.
Apr 24, 2008 | Computers & Internet
LG Flatron F700P 17" CRT Monitor Logo
53 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
