Question about Toys
Body spins on my protocol dash helicopter
Body spins as well as blades when helicopter flies
5 Suggested Answers
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
SOURCE: my micro twister helicopter starts
check the flybar connector pin. I bought two twisters and they had the same problem you described after a few hard crashes. I cut a safety pin up and made a C shape that held so i could keep flying that night(the heli had a two foot oscillation ,though). The store where i bought it gave me free replacement pins and said to put a touch of plastic cement across the outside. not zap or super glue as it will cappillary along the pin and glue it to the main upright
Posted on Dec 06, 2010
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
Rc helicopter
There might be a small knut beneath the lower set of blades that you can screw up or if its cheap a rubber band like object,
ps dont fly it if the lower blades are touching it will damage the blades (is plastic) and if they are carbon or aluminium they WILL damage the body and/or electronics
Dec 26, 2013 | Toys
The lower blades of my ev.01 helicopter are not working, how do i fix this?
Sophie, you will find that the very tiny gear at the bottom of the rearmost motor has either chewed up or come adrift. I have the same fault exactly and am trying to locate a new gear. If anyone can help locate one the please email j r siddle at hot mail dot co uk (I am sure you can work out the addy)
Dec 29, 2012 | Toys
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
Hello i just bought a s032g from dealextreme 032 does not start up react to transmitter is zero i folowd the start protocol but noting anny ideas thanks
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Aug 13, 2011 | SYMA Toys industrial Syma S032 Ready to...
My rc helicopter can not fly it spin in floor
Hi
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
Heli max hicro helicopter just keeps spinning in circles
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
114 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
