Question about 4Button Remote 474P
How to reprogram python 476p? - 4Button Remote 474P
Python 476p
May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
Oct 30, 2012 | Python Vehicle Parts & Accessories
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
Had to change the battery in my Python Keyless Start/Remote and now it wont work. How do I reprogram it
To program remote:
turn ignition on
press and release programming switch once ( the siren/horn will honk once)
press and hold programming switch
while holding programming switch, press lock button on remote ( the unit will chirp/honk to confirm programming)
turn ignition off
test remote
Oct 07, 2010 | DEI Python 1400XP Remote Start/Keyless...
How do the reprogram python 990 replacement remote
turn ignition on and within 10sec push the valet switch once then push and hold again. the siren will chirp once then push the lock button on the transmitter and the siren should beep once then let go of the valet switch and turn ignition off and remote should function properly
Jun 12, 2010 | DEI Python 990 2-Way Security...
One of my remotes will no longer operate my Python
This is a common problem on these and the equivalent viper models. We sent all our units back to viper and they have now re-released the units. We had installed these units into customers vehicles and about 50% had the same issue your having. Even after they were reprogrammed, many returned with the problem again. My advice is to contact python and have the unit replaced.
Mar 08, 2010 | 1401 Remote Start System With Dual...
I bought a 2002 jeep wrangler with a Python vehicle security system, the owners guid was not in the car and I am wondering what all this remote will do. This is all I know about the remote: FCC ID:...
the lock button should arm the alarm, the unlock should dis arm the alarm. aux on this vehicle should not do anything and the red button should set off the alarm for panic button. You cang et a copy of the owners manual at Directed Electronics website
May 04, 2009 | Vehicle Parts & Accessories
Reprogram python 990 remote
The P stands for programming. It's used when setting up the alarm system, you would need the manual for the system to tell you what can be done. I have a Python 990 and I can change pretty much everything from sensor adjustments, amount of time it turns over for starting, disabling the siren and many other settings. I found out the hard way one time when I accidentally pressed it and turned the key off and it disabled the siren. I think that's how it happened, been a while since it happened. I would have to get the manual out to be exact. You can also do the programming by pressing all 4 buttons at once and hold for 2 seconds. But you still need the manual to know what your doing. Hope this helps
Nov 11, 2008 | DEI Python 990 2-Way Security...
4Button Remote 474P Logo
42 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
AzVip
D. E. Hev
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
