MPF REGISTRATION Due to a high volume of traffic, we are currently experiencing problems with the Mobile Parental Filter server. Please follow these steps in an effort to resolve the issue. 1. From the homepage, go to Settings > Applications > Running > All. Select The Mobile Parental Filter app and tap the Clear Cache button. Press the power button and reboot the tablet. Once the tablet reboots, try to register the tablet again. 2. From the homepage, Web Browser Menu [on the right, three vertical dots] > Settings > Privacy and security [left] > COOKIES [right] > Clear all cookie data. Press the power button and reboot the tablet. Once the tablet reboots, try to register the tablet again. If these steps do not work and you continue to experience Mobile Parental Filter issues, we sincerely apologize. Please be patient and try registering the Parental Filter at a later time. PRELOADED APPS MISSING To re-install the Default Applications to your unit please do the following: 1.) Download the file called RecoverApps.zip to your computer from the following website: http://tabeo.support-tablet.com/e2-support 2.) Extract the .zip that you downloaded to your computer. You will need to use an extraction program such as Winzip (http://www.winzip.com/win/en/landing/prodpagewz17.html), Winrar (http://www.winrar.com/), or 7zip (http://www.7-zip.org/) to do this. 3.) Once extracted you should now have a folder called RecoverApps that if opened has a bunch of APK files in it. If you open it and find another RecoverApps folder in it open the second one, that will have the APK Files. 4.) Connect your unit to your computer and open the drive on your computer so you can see all the folders in it. Copy the RecoverApps folder that actually contains the APK Files into the folder on the unit called System. 5.) Once the copy is finished disconnect the unit from the computer and on the unit go to Settings -> About Tablet -> Start Wizard. Confirm you wish to run the Start Wizard. Then turn the unit off and then back on and you will be taken through the Start Wizard. Once completed the Default Applications will be re-installed to the unit.
