Question about Samsung Chromebook Series 3 XE303C12
Command key num lock
Where is the Lock Number at or what buttons do I use?
  • 335 Answers
There should be a "NumLock" key on the keyboard.....
Posted on Dec 28, 2013
4 Suggested Answers
askme1
  • 113 Answers
SOURCE: Num lock is locked !
In the bottom left hand corner there is a Key that says Fn hold that down, then press the key in the top right hand corner that has says NUM LOCK it will be printed with a TOP set of words and a bottom set. Typically two different colors. The Num Lock light should go out
Posted on Apr 11, 2009
  • 44 Answers
SOURCE: num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
Posted on Sep 09, 2009
  • 3940 Answers
SOURCE: Where is the num lock in my N150? or i've a FN key
Fn+F11
http://www.samsung.com/us/support/downloads/NP-N150-JA01US
Posted on Dec 25, 2010
Turn on num lock laptop
Yes you can go in the BIOS and there is a setting to keep num lock on by default. To get to bios restart computer and hold delete key this will get you into the bios. Some Bios's are different you should get a prompt when it is starting up to see which key you need to press to enter setup. **Note this happens before the operating system starts up*****
Nov 13, 2013 | ASUS Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Every time press for alphabetic command but it shows me a numeric command, at this moment what should i do ?
May be your Num Lock key is on. In most of the laptop Number and Alphabet are together so . Find out the Num Lock Key and on the key board and Off it by pressing the Key.
Aug 07, 2012 | Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
How can i remove numlock
Check your keyboard and find where num lock is written and press again. Something you might have to press fn,if it is written with other letter or command.
Mar 11, 2011 | Computers & Internet
When typing the letter U the number 4 pop in same for I-5 O-6P-* .
This laptop has a number pad as an alternate assignment of these right hand keys. When this is active, the Num Lock light should be lit. To unlock the Numpad, press Shift and NumLk. (There are three status lights related to the keyboard status: Scroll Lock, Num Lock (which has a 1 inside the Christmas Tree profile icon, and Caps Lock.) With Win2K and WinNT, resetting this setting requires logging out of the account after changing the setting and then logging back in. The more recent Windows OS versions should handle this without rebooting or logging out and back in.
I hope this helps.
Jul 01, 2010 | IBM ThinkPad T23 2647 Notebook
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
Sep 22, 2009 | Computers & Internet
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Samsung Chromebook Series 3 XE303C12 Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
