Question about Brother DCP-7030 Digital All-in-One Laser Printer
Print unble 72
Voltage low and down theb give this print unble 72 problem
  • Brother Master
  • 783 Answers
Print enable 72 in konica 1580w
Check the printer interface, DRIVERS re-install them. go to konicaminolta web site and down load the current drivers for that machine if they have them a legacy machine.
Feb 14, 2017 | Konica Office Equipment & Supplies
Ricoh 1200s unable to print 72
sir ricoh 1200 sp printer ptint unble 72 error
Dec 19, 2013 | Office Equipment & Supplies
Call Service 6000: 0037842
Call service in the 6000 range describes a problem with the fuser of the machine. you did not mention the model number of the machine, but on some of the machines this can be reset in the sevice mode under u163. Unfortunately on some of the smaller machines this will mean a fuser replacement.
Dec 14, 2013 | Kyocera Office Equipment & Supplies
My printer is Epson Dot Matrix 300+,I use tally 7.2 for accounting, when i give print in quick draft mode in tally,(my paper size is 8.5x12 inch) paper area is seen as 80 col. & 72 lines. and print...
You should be able to reduce the size of print somewhere in your program rather than printing at 100%. Try to find where you can change to perhaps 95%. You will still be able to read the print. Experiment with the percentages and check the preview prior to printing. You may need to check the printer properties to find where you can change from 1oo%.
Oct 20, 2017 | Epson LX Office Equipment & Supplies
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Print Unable 72
brother dco 7030 print unable 72 troubleshooting and routine maintenance
Oct 04, 2012 | Brother DCP-7030 Digital All-in-One Laser...
I have a Akai am-72 digital amp just purchased. It has a Direct Opeation control allowing you to adjust tone and balance manually when switched in the off position. Does not work. Mabe a fuse? Help
What's the actual model number? 'AM-72' has no hits online.
Fuses are for overall power protection and aren't for individual low voltage functions. Have you looked at the manual yet? 'Direct' modes usually BYPASS tone and balance controls.
Aug 13, 2011 | Audio Players & Recorders
The temp setting shows 78 degrees,lower to 72 degrees /it stays for 15 sec and returns to 78 degrees no codes
you may not be giving the a/c enough time to cool down to 72 the reason it goes back to 78 is that is the temp in the room at that moment put on 72 and give it about 20-30 min. to see if this helps
Jul 03, 2011 | Sharp AF-S120FX Air Conditioner
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Brother DCP-7030 Digital All-in-One Laser Printer Logo
394 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
