Why is my washing machine leaking water from under machine after washing completes
  • annadye_34 May 18, 2009
    what plasic needs super glue? it leakes from underneath after wash finished
Attach plastic with superglue
Posted on May 18, 2009
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Lg top loaded WF-T953A
Check for trapped lint causing the water to back up. Likely the leaking water is due to a restriction forcing the water to go elsewhere, and is causing it not drain fully.
May 07, 2014 | Washing Machines
After the clothes finish completely the water is leaking from the bottom of the washing machine
Do not but Do not under any circumstances continue using a leaking machine.
HighVoltage +Water=Electrocution
Get a Techo to check it out and survive to tell the tale.
Oct 24, 2009 | Roper RAS8445KQ Top Load Washer
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
