Question about Curtis Televison & Video
Curtis LCD3717A won't turn on, continuous blue flashing.
Hi there, would appreciate any help you could give. I have the exact same TV Curtis LCD3117A, the tv does not turn on. When I press the power button the blue light flashes continuously until I cut the power off by disconnecting the plug. I've owned this TV for about 2 years now and have noticed some sudden cut offs where the TV restarts to its logo then continues with its regular function. Any help is greatly appreciated thank you.
    Top Expert:
  • Curtis Master
  • 45,112 Answers
Your TV probably has a failed power supply.
Posted on Dec 27, 2013
4 Suggested Answers
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
roety
  • 585 Answers
SOURCE: MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 26, 2009
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
I have a Curtis flat screen tv that when you turn it on after about a minute the picture starts going on and off repeatedly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 10, 2016 | Curtis CMMT32 32 in. LCD TV
Curtis LCD3717A it wouldn't turn back on an blinks red when its plugged in an it's usually blue we gave it a little bit an tried it came back on but now it want any information is greatly appreciate
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 07, 2015 | Curtis Televison & Video
Blue flashing light on curtis 37
sounds like you have faulty main board..
so its better if you send it to the professional tv tech
Nov 03, 2012 | Curtis 37" LCD TV
Tv cuts off
What is the exact model number to your Curtis TV?
Sep 27, 2012 | Curtis Televison & Video
Ttv keeps cutting off
Is this a Samsung tv? Mine did this and I had to upgrade the capacitors in mine. It costs less than $10 and takes about an hour. There are how to. Hope this helps videos on youtube
The TV does not power up. Power is getting through the cord but nothing happens within the set. Totally dead.
Hi Larry,
May I know the exact model no. of your unit, it is printed at the back cover, receipts and on the manual. It will help diagnose where the exact fault came from and give you an accurate solution to your problem.
Jdvillanueva
Nov 20, 2011 | Curtis LCD1575 15 in. LCD TV
But curtis lcdvd320a with no remote can"t get universal to work
I am having the same proplem for Curtis lcd3717a. I tried a RCA unversial romote crcr350. Can not get to work. Any universal romote that would work with this TV
Dec 11, 2009 | Curtis CMMT32 32 in. LCD TV
Installation help
Hi daddi....could you please update your post to include the entire specific model number of your TV and I will be better geared to offer you comprehensive steps without errors.
Aug 02, 2007 | Curtis Lifestyle DVD System
Televison & Video Logo
217 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
