Question about Cutler Hammer Electrical Supplies
Can I replace a CEB CU/AL QB breaker with a QBH CU one?
My home is wired with aluminum wiring. Even when the breaker is set to "on", there is no power to outlets and lights. Should I replace the breaker?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
Nope breaker has to be rated for the aluminum wiring. if your home is wired with al wiring u need to be really worried bout that. it becomes a fire hazard awhile. should only use al for larger size wires and personally I wouldn't do that either
Posted on Sep 15, 2016
mydogisk
  • 50 Answers
SOURCE: I need a new 15 amp breaker and can not find Sylvania
Since Sylvania changed to Chanllenger later own, there are only a few options, " hope depo" may have a replacement breakers, but Cutler Hammer "BR" style should work. If they won't fit i would call the oldest electrician in town and see if he has a few in the van!
Posted on Apr 10, 2009
  • 454 Answers
SOURCE: Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
Posted on May 01, 2010
  • 1044 Answers
SOURCE: The breaker itself does not seem to trip
It is a clear case of metal contacts getting heated/melted/burn out due to overload/short-circuit inside. Please get the circuit breakers replaced with a new one to avoid fire hazard.
Posted on Jul 31, 2010
SOURCE: 1 question can Cutler Hammer breakers have the
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Posted on Feb 18, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: My old Bryant circuit breaker
Hello
The spring in the breaker is worn.Best to shut off main and disconnect breaker,pull out of box and take it to a electrical hardware store.
Home depot and lowes sell many different types.The numbers you gave match nothing i can find.
Posted on Mar 31, 2011
Has there ever been a product that appears to be copper covered aluminum household wire ,14/2
Yes, when copper wire is repeatedly heated / cooled, then it will experience "Metal Fatigue", where the connection point will snap right off. Depending on the County (State) you are in, there are different variations for building "rules" or 'code'. The "Building Code" is a LAW, that has penalties for not building to 'code'. But between when the building was inspected, and now, (2015) there have been many changes to improve the SAFETY and HEALTH of living in the home. The NEC, or "National Electrical Code" specifies the length a wire must be available inside the electric box. Once this length is less than the required minimum, then you need to replace the ENTIRE WIRE RUN. . . . . . There was a time that ALUMINIUM wiring was used in homes, in some states(provinces). You need the CORRECT SWITCHES and OUTLETS for AL wiring, they are not the same as the common(Home Depot) or hardware store products. They MUST be labelled for AL-CU wiring.... your FIRE INSURANCE depends on this.
Dec 04, 2015 | Kitchen Ranges
What is the BEST aluminum to copper 220V connection
http://www.homedepot.com/p/AlumiConn-2-Port-Al-Cu-Wire-Connector-10-Pack-95015/204958912?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-VF-PLA-D27E-Electrical%7c&gclid=CPyYyb-TzNMCFYq2wAodepICWw&gclsrc=aw.ds
The only way considered safe to connect copper and aluminum is through a splice connector. Specifically, you have to connect the wires individually so they are not prone to corrosion.
Semper Fi,
Z
Apr 30, 2017 | Dayton Gas Furnace Heater
Switch /comb gets hot in wall
This is fire hazard.
Call electrician.
What is plugged into outlet?
Are wire and breaker sized correctly?
Do you have aluminum wire?
http://waterheatertimer.org/Color-codewire.html
Otherwise turn off circuit breaker, pull out device and inspect for melted wires.
Use nose to find source of heat and burning.
Inspect if you have aluminum wire. Do not use aluminum wire.
Aluminum wire will burn down your house today.
Use only copper wire.
Replace combination device with new.
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Apr 17, 2013 | Pass & Seymour #691CC6 Comb...
I have a Hampton Bay window A/C model HBD160-E (Home Depot). It recently started tripping it's 15A circuit breaker. Has been plugged in to same outlet for going on 11 years. Other than this unit still...
Look at the serial tag. It should give you the amperage. If that is close to 15 Amp then the circuit breaker has obviously been running at an elevated temperature (due to its inherent resistance), and is now "worn out". You need a new breaker. If the amperage is, lets say, 13 Amp you should put in a 20 Amp breaker. If you have aluminum wiring the connection could be loose, which has the same result. Make sure the wire is al least # 12.
May 24, 2011 | Heating & Cooling
My old Bryant circuit breaker keeps turnin off and cannotr be re-set. It is a type CU 10-14 AL 8-12 What kind of breaker it is and what would I replace it. ZM
Hello
Mar 31, 2011 | Bryant Electrical Supplies
Can a Cutler Hammer 2 pole 100 amp CH series circuit breaker be connected to 2/0 aluminium wire in a branch feeder circuit?
I answer questions for free
I specialize and timers and electrical devices
Looking up your breaker at Eaton, I found the chart that shows below:
Other than the chart, I do not know the specifics of your breaker.
You can add a comment, and I can help you with your wiring project.
Another good source of information about specifics are your local Graybar electric supply house, or any local supplier that specializes in electric wiring.
Having a local electrician stop by and look at your project for a fee might be a good investment long term because that person knows local codes and restrictions.
http://www.eaton.com/EatonCom/Markets/Electrical/Products/ResidentialProducts/CircuitBreakers/CHStyle34-inchBreakers/index.htm?ssSourceNodeId=4522&ssSourceSiteId=EatonCom
The #1 Data Table from manual shows CU/AL which is copper/aluminum
2/0 wire fits CH145 CH245 CH150S breakers
See the manual
http://waterheatertimer.org/pdf/SA00400006E.pdf
Nov 02, 2010 | Cutler Hammer 100 Amp Main Breaker...
When replacing a switch with bare aluminum grounds can a copper ground be used from the new switch to the aluminum grounds on the box?
You need to make sure the wire connector has a listing AL/CU on it. These have been evaluated for a mixture of copper and aluminum combinations. BTW the switch conductor is most likely tinned copper, this slowed down the oxidation process.
Jun 05, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
We are having to replace a single wall oven, electric. the wires coming out of the wall are aluminum. Are they acceptable to use?
I would say yes, using the proper connectors, but local electrical codes may vary. You should confirm with a local electrician or building inspector.
Nov 20, 2009 | Washing Machines
Apr 03, 2009 | Sylvania Electrical Supplies
Electrical Supplies Logo
315 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
