Question about Leupold Optics
Gx3 doesnt work
Red circle doesnt display
One channel's red led is always on and no sound
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/QSC-GX3-Amps-manual/id/23107ag606/t/2/
See page 7.
"CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off
Mar 17, 2011 | QSC GX3 Amplifier
BUILT IN ORINOCO WIRELESS ADAPTER DON'T DISPLAY ANY NETWORKS
Maybe your internal antenna has come unplugged. Try opening the back plate and looking at the wireless card, usaually they have a black cable and white cable pressed onto two studs on the wireless card. carefully try to push the cables down firmly onto the card. NB this may void your waranty make sure battery is taken out before you start and not plugged into mains.
Mar 25, 2010 | MPC Computers TransPort GX3 Notebook
Where can i find drivers for a micron trans port gx3
www.mpcdrivers.com has all the drivers for GX2,GX3,T2000,T2100 and other.
Jan 18, 2010 | MPC Computers TransPort GX3 Notebook
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
Red cross in circle comes up n doesnt do any thing it is ipod 80g
HI! I WAS TOLD THAT YYOU NEED TO DOWNLOAD THE LATEST VERSION OF ITUNES AND THE PROBLEM SHOULD BE SLOVED. TRY IT OUT AN POST BACK SO WE KNOW IF IT WORKED OUT! GOOD LUCK : )
Oct 01, 2009 | Apple 160 GB iPod Classic (Silver) +...
I WISH TO KNOW THE NAME OF THE VIDEO CONTROLLER DRIVER FOR MICRONPC TRANSPORT GX3
All mpc computer drivers are available for that model at http://www.mpcdrivers.com
Aug 04, 2009 | MPC Computers TransPort GX3 Notebook
SONY RDR-GX3 region code unlocking
prepare: your one for all
1. select dvd device on remote
2. hold magic button until flashes twice/comes out
3. enter device code 0533 (this programe the GX300 as the DVD choice in your one for all)
Now program buttons 1..5 with the following codes using the instructions below:
1 - 189
2 - 255
3 - 095
4 - 221
5 - 079
1. hold magic button until rabbit comes out
2. press 994
3. press magic
4. enter 3 digit code from above
5. press button (1..5) where to program it
6. repeat steps 1 to 5 for all keys.
have it a go:
1. remove disk, put player on standby
2. press 1,2,3,4,5 - success is displayed and plyer starts up
3. press 1,2,3,4,5 - player shuts down and BINGO!
Good Luck!!!
Mar 22, 2009 | Sony RDR-GX3 DVD Recorder
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Optics Logo
59 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
