Monitor turns off
Hi, i have an Advent allin one pc and the screen keeps cutting out. I will be surfing the net and i'll hear a click and the screen goes blank. So i have to turn it off by holding in the power button and then turn it on agian, i understand that this is not good for the pc but what else can i do? I think it is over heating or something and the sound i hear is a trip switch but sometimes i can be on the pc for the whole day and it doesn't break down. Can you help me please?
  • 818 Answers
I'm not familiar with that particular model, but in common with all computers there are a few things that could cause the symptoms you describe.
A heat build up can cause that to happen - like a laptop computer that cannot draw in air from underneath because it is resting on a desk/carpet .. air vents on the base of a laptop/computer should be kept clear. Ideally, laptops should be on a holding stand that allows an air gap underneath.
However, you say that it is only the screen that goes blank - the computer is still powered up. This suggests one of two things.
There may be a fault in the video circuitry (the card or chip) which 'throws' the display every now and then. It could also be faulty/failing RAM which, depending on what you are doing at the time, can cause the exact same symptom.
Just to confuse matters even more, a faulty or failing power unit can cause the same symptoms, though admittedly, it would be unlikely that your computer would remain powered up whenever the fault occurs.
Take the easiest first .. search for 'Free windows registry repair 1.2' and install it. Use it to scan the computer for registry faults and then click on 'fix errors'. If there are any registry faults causing the problem .. hopefully they will be fixed.
If you can, remove your RAM - the memory modules - from your computer and take them to a computing shop where they can be tested. Alternatively, can you borrow similar RAM from a friend and install it in your pC to try and re-create the fault? If you do this and the fault doesn't reappear - you know you have faulty RAM.
It's difficult fixing a computer and identifying faults unless you have it there in front of you. I would suspect the RAM. Take it out and have it checked.
Posted on May 18, 2009
The width of PC screen has suddenley widened, so that data is not viewable, how to I readjust it?.....
Right click on desktop and click screen resolution. Then select the recommended resolution for your monitor and click apply then OK. This sholud solve your problem.
Mar 02, 2014 | Dell 1702FP UltraSharp 17" TFT LCD...
Hi I have broke my screen on my advent 8117 I've
Try connecting the laptop to an external monitor. Power up the external monotor first then boot up the laptop and the video will automatically switch to the external monitor.
Apr 07, 2012 | Computers & Internet
Hi. i'm trying to get my girlfriends notebook(advent 4213) connected to the net. i am using my own wireless net but when i click on the net it comes up saying this page cannot be displayed. do i h
If the Advent notebook normally connects to the internet without problem on her network, then you need to check the following:
1. That she does not have any proxy connection setting in her web browser that you do not use on your own network.
2. Check that her wireless adapter is configured to Obtain an IP address automatically and also Obtain DNS server address automatically.
3. Check the status of the wireless adapter connection and ensure that the Advent notebook has been given a valid IP address, i.e. if your are connecting to a wireless router on your network, you should see an address something like 192.168.x.x where the x.x depend on how your router is setup. If you see a 168.x.x.x address then the notebook is not getting a valid, routable IP address and you should try to do a Repair of the network adapter connection. Repair may also be shown as Diagnose and repair depending on which version of Windows is used.
Jan 07, 2012 | Computers & Internet
Which buttons do i press to turn on the internet on, on a dvent net book
Hi
do you mean to enable the wireless switch so that you can use the internet
as you have not told us which model you have i can not tell you where the switch is
please try some of these options if your model is mentioned
Advent 7086 ---- Button next to the power button
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
hope this has helped you
many thanks
Aug 17, 2011 | Advent Netbook
Cracked LCD Screen for Advent 4211C Netbook
try this site if they don't have it e-mail the guy he can help you I been with him since 2000, its http://cbear.net/laptopandaccessories.aspx
Jun 27, 2009 | Advent 4211c Notebook
Lcd connection
It would be uncommon for a laptop not to have a function key, Fn. This would be normally located somewhere bottom left of the keyboard often after the CTRL key and/or before the Windows key. Further, it is often required to press the Fn key + F? key where the F? would be one of the F keys with the small monitor icon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Xcd Computers & Internet
Problems with advent 7113 backlight
i,d suggest trying the laptop on an external monitor firstly.
this will eliminate motherboard fault.
then if it displays fine on the external monitor.
possibility of Faulty Inverter Or CFL Tube.
Mike @ compurepair.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
