Question about Microsoft Computers & Internet
Cisco IPN4320 is not recognized with Xbox One
Can I play playstation 3 online with a E1000 cisco router?
You should be able to connect to the Internet provided the PS3 wireless segttings is configured correctly.
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Aug 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Cisco router 3845 cannot recognize HWIC-2FE.
Hi, what IOS are you running, Cisco recommends IP Base 12.4(20)T
May 16, 2011 | Cisco HWIC2FE= Network Adapter
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Im tring to open my nat for xbox360 and i dont know what to do to get them all to say open
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Jan 07, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Mar 14, 2009 | D-Link DGL-3420 Wireless Adapter
I have a Cisco 7206 and it does not recognize a pa-8e port adapter
Hi Ckrebs,
Can you check what is the ios version of the 7206 (the one not able to recognize the PA-8E)?
Minimum versions of IOS required for pa-8e are the following:
Cisco IOS Release 12.2(4)B or a later release of Cisco IOS Release 12.2B
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/ethernet/pa-8e_10baset_install_config/3494prep.html#wp1024649
Check the ios of the router if it supports the PA since you were able to isolate that it's not a faulty PA-8E (by testing it to another 7206 chassis).
Once checked, can you provide the show version and show diag output?
Regards,
ex_ocsic_cat
Oct 20, 2008 | Cisco (PA-8E=) Expansion Module
Computers & Internet Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
