Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
No pto,brakes, and steering
Pto, brakes, steering, and three point quit working. I was raising the three point hitch and the blade was frozen down and it started raising the front of the tractor and then the blade broke loose and then it all quit working.
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
I have a craftsman z7000 mower. When I engage the PTO the blades start working but after about a minute they stop, like I turned the switch off. I waited a minute and tried again, same thing, it worked...
something is loose, pto switch connectors maybe loose or corroded, wires at the pto, bolts on the pto there should be three of them. hope this helps Tim
Apr 24, 2011 | Garden
Pto, fuel gauge, three point hitch all stop functioning at the same time
check the acc fuse
also check wires under seat because of short in them will not let pto work
Jun 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Blades rotate on tractor when new belt was put on
be sure you have the correct belt for that mower?
Even though your deck is raised to disengage the
belt it may need to go up a small amount more,try pulling back on the deck raise handle to see if that helps,and find a way to keep it at that higher point if that worked or run the new belt for awhile and see if that makes a difference.
Check the belt guards to see if they are close to the belt as possible while engaged,but not hitting the belt
and when disengaged guards should be hitting the belt somewhat to help keep it from turning.
and yes be sure you have good belt brake pads and know they have good tension and hitting in the proper place
May 05, 2010 | Garden
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
47 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
