Question about Pioneer Audio Players & Recorders
Can I connect a JBL 4 ohm 12" subwoofer to Pioneer VSX-D510 ?
  • 336 Answers
SOURCE: sir i want som parts of (pioneer vsx-d510)(PAC010A
Got to this web site: http://mcmelectronics.com/product/PAC011A or goggle pioneer parts.
I doubt that they are both bad.
Posted on Mar 06, 2009
  • 30 Answers
SOURCE: pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Posted on Aug 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
one5oneproof
SOURCE: Pioneer VSX-822-k Subwoofer problem
I had the same problem. Dont know why the receiver set it up this way but grab your remote, go down to the lower right and select ch setup. Keep on pressing it till your receiver says SW. Then press lev+ on your remote to change the db on your powered sub.
Posted on Oct 31, 2012
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
How do I get the powered subwoofer to work with a pioneer VSX-D510
You plug a subwoofer RCA cable into the Subwoofer Preout from the back of the VSX-D510 and to the input on the back of the subwoofer. If there is a red / white connection don't sweat it, just use the red. Should work fine.
Feb 14, 2016 | Pioneer Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
How to hook it up with sub dvd
Not sure what a "sub dvd' is but here's the manual. The Subwoofer Pre Out would provide a Line Level feed for a powered subwoofer, once it is configured to do so.
Page 14.
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
Jan 30, 2011 | Pioneer VSX-D510 Receiver
How to connect my 12'' 2 coils subwoofer?
It really depends on your amp most amps you want to keep a 4 ohm load . If you have a high end amp like Rockford or JBL they are 2 ohm stable a 2 ohm load means the speaker will work harder but my not ne safe for your amp . This is how you make a 2 ohm load you have 4 imputs 2 + and 2 - run 2 sets of speaker wire just like you have 2 speakers then take the free end the 1s going to the amp twist them together + to + - to - you can only do this if your amp is bridgeable and is 2 ohm stable look on your amp out puts most amps go to the left + and right - hope this helps
May 13, 2010 | Pioneer TS-W307D4 Car Subwoofer
How to connect to an subwoofer
You need a subwoofer cable then you attatch the cable from the back of the amp into the sub and power on the subwoofer and amp and hey presto your away.
Aug 04, 2009 | Pioneer VSX-D510 Receiver
Pioneer receiver vsx-d510 sub not working
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
16 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
