Question about LG Washing Machines
I need LG T8107TEFTO service manual.
It displays PE on the display.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
You may have a Drain Problem due to clogged line or Bellows. Bellows is the drain for the Tub which requires you to take the washer almost completely apart! If you are not that Handy call for service it is worth it. If you are go to YouTube and enter LG disassembly procedure. Good luck with those Spring Seals!!!
Posted on Dec 27, 2013
  • STEVEN NEUNHOFFER Dec 27, 2013
    Also the "Service Manual" will not help you. It is electronic on a computer program that costs as much as the machine does. Also check your filter it is on the bottom left and get ready for water when you check it!
2 Suggested Answers
  • 6277 Answers
SOURCE: LG wm1460fhd displaying PE what
'PE' on LG's decodes as 'sensing water pressure error' (really clear- inlet or outlet?!).
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 28, 2011
My washing machine LG - model # T7517TEPT0 is displaying PE error - please advice to enable to fix the repair
PE stands for locked rotor meaning the motor is not able to turn either electrically or physically
May 01, 2017 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Washing maschine runs for 5 sec and trip
PE code stands for "Pressure sensor Error" check the sensor and the small tube that is connected to the outer tub for debris.
Dec 18, 2013 | LG WM-2277HW Front Load Washer
My Lg problem is FE?What Ihave to do?
Turn the water taps clockwise to close them and unplug the washer if "FE" or "PE" appears on the display. The "FE" error means the water valve is faulty and the washer is overfilling. "PE" means the water level sensor is faulty.
Hope helps.
Sep 11, 2011 | LG WM-2277HW Front Load Washer
Dish washer displays pf code
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Jul 18, 2009 | LG Dishwashers
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
